bigb Posted February 15, 2018 Share Posted February 15, 2018 I've been debating on whether or not I really need much work bench space in my tiny outdoor hobby area. I presently have two work tables, a 32" X 36" and a 32" X 48".I use the area for smithing and for grinding work and oxy acetylene work. Seems like at least one of the tables is always piled up with "stuff". They are great solid tables made from 1/4" X 2" angle with heavy steel tops. If I got rid of one it would help with room for the leg vise and a grinder stand. I am thinking on getting rid of the 48" one but would hate to give it up then need it later. My property is small and I am out of storage room. How much table/bench space do you guys have/need in your hobby smithy? I do have a large indoor shop with several benches and a 4 X 5 welding table but no room to put another one in there with the trucks I keep in there. Link to comment Share on other sites More sharing options...
Glenn Posted February 15, 2018 Share Posted February 15, 2018 Put everything on wheels. Storage shelves under the table. Easy to move and make room when you need to. Remember the truck is on wheels and can be moved outside the shop when you need a hard floor or extra room. Just remember not to leave the truck outside over night or it will never get back into the shop. ALWAYS move the truck outside if you are going to do any grinding. Or choose the *other* color paint you always wanted for that truck. (Do not ask) Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 15, 2018 Share Posted February 15, 2018 What do you need: 1 sq foot to 100 sq feet depending on what you are doing and how you do it. I know folks who use very little benh space as they work on small projects one at a time and so never have much out. Other like to work in batches and batches of batches and they tend to like to have a lot of space to group stuff in the same process at the same time. How heavy is the steel top? 1" thick or heavier? Bases can be rebuilt, it's usually finding a massive slab for the top that's the hard part. Could you store just the top up against a wall? Link to comment Share on other sites More sharing options...
genesaika Posted February 15, 2018 Share Posted February 15, 2018 I like to do draft work on my work bench so mine is 4 foot by 4 foot. It also has my drill press, bench grinder and vise mounted to it. I have a full range of the angles burned into the top of it too. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 17, 2018 Share Posted February 17, 2018 Some of us suffer from "flat surface syndrome", the more work benches we have the more stuff is piled on top. Time to build another one. Link to comment Share on other sites More sharing options...
Please sign in to comment
