Jacob Palmer Posted February 2, 2018 Share Posted February 2, 2018 I found this youtube video on making a simple burner for a gas forge. I have made a burner to melt aluminum in a foundry before. With most burners (and the one I made) I find that they cost a lot to make or require a lot of up-keep. This one seems almost too simple. What do y'all think? I'm not looking for it to last my whole life but to just get started in gas forges. https://www.youtube.com/watch?time_continue=5&v=67rxU02fv6o (P.S. I would make quite a few modifications like an air flow regulator and such.) Your boi, Jacob Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 2, 2018 Share Posted February 2, 2018 Did you look at the gas forge section on the site? or read the topics Forges 101 with 613, Burners 101 with 919 posts, Burners 101 with 211 posts, or the Frosty burner? These designs have been tested and ACTUALLY work. Quote Link to comment Share on other sites More sharing options...
Binesman Posted February 2, 2018 Share Posted February 2, 2018 If youre starting out use a known design and follow it. If youre looking for something less complex to make go with a frosty t burner. There a clear and easy to follow instructions pinned on this site for them. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 2, 2018 Share Posted February 2, 2018 I looked at the video and, while the threaded plug is certainly no breakthrough, it is a useable form of gas assembly saddle for linear burners; it almost comes up to deserving honorable mention. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2018 Share Posted February 2, 2018 I wondered about getting a perfect alignment by hammering the parts in and how would you correct if it they were off? Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 2, 2018 Share Posted February 2, 2018 More hammering? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2018 Share Posted February 2, 2018 I tried that personally. Turns out the second concussion a month after the first did NOT help things improve... Quote Link to comment Share on other sites More sharing options...
Jacob Palmer Posted February 2, 2018 Author Share Posted February 2, 2018 6 hours ago, Binesman said: If youre starting out use a known design and follow it. If youre looking for something less complex to make go with a frosty t burner. There a clear and easy to follow instructions pinned on this site for them. Though I have already checked many forums for burner blueprints. (Like for a stinkin hour) I had not found any that were simple or cheap enough for me. The "Frosty T" looks great and is what I'll probably end up using. Thanks for the suggestion! 1 hour ago, ThomasPowers said: I wondered about getting a perfect alignment by hammering the parts in and how would you correct if it they were off? If I went with this model I would use a tap. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 2, 2018 Share Posted February 2, 2018 An entire stinkin' hour?! Really tough going there, lad. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2018 Share Posted February 2, 2018 If you use a tap; you might as well build the "T" burner anyway and use it's alignment ideas... Quote Link to comment Share on other sites More sharing options...
sfeile Posted February 2, 2018 Share Posted February 2, 2018 I'm pretty new too and don't have a big budget. Considering this is something that is going to mix fire and an extremely volatile gas, it was something that I didn't feel I wanted to skimp on. My recommendation is to go with something tested and proven. This is a pretty labor intensive craft to be complaining about a whole hours worth of research. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 2, 2018 Share Posted February 2, 2018 2 hours ago, ThomasPowers said: I tried that personally. Turns out the second concussion a month after the first did NOT help things improve... Hammering is NOT what people mean when they say, "use your head Thomas!" Two concussions? HAH I did it in one! Ooooh what's THAT? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Jacob Palmer Posted February 2, 2018 Author Share Posted February 2, 2018 1 hour ago, ThomasPowers said: If you use a tap; you might as well build the "T" burner anyway and use it's alignment ideas... Yeah, that's what I was plannin'. 52 minutes ago, sfeile said: I'm pretty new too and don't have a big budget. Considering this is something that is going to mix fire and an extremely volatile gas, it was something that I didn't feel I wanted to skimp on. My recommendation is to go with something tested and proven. This is a pretty labor intensive craft to be complaining about a whole hours worth of research. Sfeile, I wasn't complaining, I was merely expressing my misfortune with finding information. I have used very similar propane burners before. I was looking for a simpler design than the ones I have made. When I worked on my aluminum foundry I spent months of work on researching. I expected my knowledge to carry over even a little... 1 hour ago, Mikey98118 said: An entire stinkin' hour?! Really tough going there, lad. Read note to Sfeile, the same applies to you. Quote Link to comment Share on other sites More sharing options...
sfeile Posted February 2, 2018 Share Posted February 2, 2018 47 minutes ago, Jacob Palmer said: Sfeile, I wasn't complaining, I was merely expressing my misfortune with finding information. I have used very similar propane burners before. I was looking for a simpler design than the ones I have made. When I worked on my aluminum foundry I spent months of work on researching. I expected my knowledge to carry over even a little... Didn't mean to sound like such an xxx, and I apologize. I could have worded that better. There is a lot of info here, I've been tapping into it for quite some time even before I signed up. I don't know anything about building a foundry. The only foundry work I have ever done was back in Jr. high and that was more than a couple weeks ago for sure. I do know I built my first burner and it was one that was supposed to be pretty good, but cheaper than some of the more "tried and true" versions. It ended up costing me more in the long run because it lacked in efficiency and I ended up replacing it with a better model. So despite my initial crassness, my intent was honest. Go with a good design to begin with. They may cost a little more initially, but they are proven and will serve you much better. Quote Link to comment Share on other sites More sharing options...
MotoMike Posted February 2, 2018 Share Posted February 2, 2018 My next burner will surely be a frosty t. my first and current burner is a Reil design with Bourdeax modification. budgetary concerns at the forefront, I can't imagine a cheaper proven burner to build than a Ron Reil. Quote Link to comment Share on other sites More sharing options...
Jacob Palmer Posted February 2, 2018 Author Share Posted February 2, 2018 5 hours ago, sfeile said: Didn't mean to sound like such an xxx, and I apologize. I could have worded that better. There is a lot of info here, I've been tapping into it for quite some time even before I signed up. I don't know anything about building a foundry. The only foundry work I have ever done was back in Jr. high and that was more than a couple weeks ago for sure. I do know I built my first burner and it was one that was supposed to be pretty good, but cheaper than some of the more "tried and true" versions. It ended up costing me more in the long run because it lacked in efficiency and I ended up replacing it with a better model. So despite my initial crassness, my intent was honest. Go with a good design to begin with. They may cost a little more initially, but they are proven and will serve you much better. Thanks, do you think that the frosty t design would work? It doesn't seem too complex, but is it one of those tried and true methods? The one I ended up building for the foundry was Grant Thompson's Gas Blaster. It worked well, but it was a very complex build. It could be adjusted better, but in the end, was just needlessly complex. 4 hours ago, MotoMike said: My next burner will surely be a frosty t. my first and current burner is a Reil design with Bourdeax modification. budgetary concerns at the forefront, I can't imagine a cheaper proven burner to build than a Ron Reil. That Ron Reil also looks pretty good. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 2, 2018 Share Posted February 2, 2018 Maybe. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
sfeile Posted February 2, 2018 Share Posted February 2, 2018 4 hours ago, Jacob Palmer said: Thanks, do you think that the frosty t design would work? Frosty's design looks like a very good one. I've read a number of his posts, and at the risk of swelling his head, he knows what he's talking about. I would recommend staying with the same sizes of things he lists for materials though. They are that size for a reason. I think part of the inefficiency of my first burner was not having my top reducer being the correct size. It was based on the Reil, and I don't think I was getting correct airflow. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted February 2, 2018 Share Posted February 2, 2018 1 hour ago, Frosty said: Ooooh what's THAT? Squirrel.... My wife's favorite saying when something detract's her. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted February 2, 2018 Share Posted February 2, 2018 23 minutes ago, Jacob Palmer said: Thanks, do you think that the frosty t design would work? Quite a few of us on here have used it and can confirm that it works well IF you follow the instructions exactly as they are presented. Any deviation in parts or dimensions (whether Frosty's design, Ron Reil's, or any other proven design) can negatively affect the performance and/or efficiency of the burner. Quote Link to comment Share on other sites More sharing options...
