tech413 Posted January 30, 2018 Share Posted January 30, 2018 Started my new guillotine tool! Got pieces all cut, just need to get material for dies and weld it all up! Will update with progress. Quote Link to comment Share on other sites More sharing options...
Ranchmanben Posted January 30, 2018 Share Posted January 30, 2018 Looks good so far! For some strange reason I held off buildinging a guillotine tool for a long time. Now that I’ve got one I couldn’t be without it. Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted January 30, 2018 Share Posted January 30, 2018 Looks good. Make sure you size the dies to match common stock in your area. I made my dies out of cold rolled steel that I case hardened after they were all ground and polished. The case hardening works great on the working surfaces, but the struck end of the top dies started showing some swelling right away. It's better than bare mild steel, but it's still not as tough as annealed high carbon is. I hadn't made dies before so I didn't realize that the round tenon dies benefit from not having sharp corners where the dies meet. So long as the dies "stop" with the proper radius at the opposing ends of your dies, you can rotate the stock and get a nice perfectly round tenon. I tack welded the dies together and drilled the tenon holes to make mine. That left a sharp transition where the dies meet which pinches out extra material. I've gotta find time to grind down the corners and smooth out the transition. I also learned that longer and larger dies aren't an asset if you're working solo. My top die is roughly 5" long by 1.5" x 1/2" or thereabouts. It's weight takes a lot of inertia to get moving. A 2lb hammer blow barely makes anything happen. If I make new ones, I'll make the bottom die as tall as I can to shorten the top die. I've seen some where the bottom die pocket was closed in. Scale accumulates until the bottom die wedges tight. I have a buddy who's got one with a hardy post welded to a bottom plate. There's a little hole so he could use a punch or something to knock a stuck die out. If it's at all feasible with your anvil, you can make your tool so the bottom die is sitting on the anvil face. It'll fall out when you lift the tool off the anvil, but it won't get stuck, and the overall tool would weigh a lot less. Quote Link to comment Share on other sites More sharing options...
tech413 Posted February 3, 2018 Author Share Posted February 3, 2018 Thanks for all the input! My dies for now will be cold rolled, once I am happy with the design of them, there is tool steel available locally in the same dimensions. I don't want to make dies out of tool steel to find out I don't like how they are made. I think I will go with the idea of putting a hole under the bottom die, I plan to be able to use this in the vise as well so I need the plate to support the bottom dies. I plan to make a bunch of different die configurations so we will see how it goes. Just wish I had a millling machine set up at home. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 6, 2018 Share Posted February 6, 2018 Split the difference and make them out of leaf spring of a common size. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted April 6, 2018 Share Posted April 6, 2018 On January 29, 2018 at 10:17 PM, tech413 said: Will update with progress. Did you make any progress? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted April 6, 2018 Share Posted April 6, 2018 its only been 2 months since his last post, dont rush him Quote Link to comment Share on other sites More sharing options...
Daswulf Posted April 6, 2018 Share Posted April 6, 2018 Well ya know, I was just curious and thought I'd nudge him and see if maybe he forgot or got side tracked. I know I have before. Quote Link to comment Share on other sites More sharing options...
holder Posted April 7, 2018 Share Posted April 7, 2018 What is it used for? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 7, 2018 Share Posted April 7, 2018 Making precise dents or cuts in the workpiece, they can be ornamental or used for specific physical effects. For example perhaps you want a very precise transition from blade to tang on a knife; a guillotine tool can provide that. Or perhaps you want to separate some mass, you can use a guillotine tool with butchering inserts to do so. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 8, 2018 Share Posted April 8, 2018 I used a common size leaf spring for the die stock in mine. When you weld up the guides use the die stock you're going to use and place a business card between for a spacer. Without a little deliberate space the dies may be too tight to move freely, too much space and they'll wobble and you need precision for a guillotine to work properly. I angled my dies at 45* to I can work across or longitudinally on long stock, say I wanted to fuller a sword. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Dillion Brian Grant Posted August 4, 2018 Share Posted August 4, 2018 Haha yup frost heck actually I'm bout to go outside and make a guillotine tool also my dies are gonna be leaf spring as well Quote Link to comment Share on other sites More sharing options...
MotoMike Posted August 4, 2018 Share Posted August 4, 2018 Having trouble picturing how it will go together. are all the pieces shown? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted August 4, 2018 Share Posted August 4, 2018 Quote Link to comment Share on other sites More sharing options...
MotoMike Posted August 4, 2018 Share Posted August 4, 2018 Ooh, that looks pretty sweet. Would you put a hardy stub on that? Thanks Steve. Quote Link to comment Share on other sites More sharing options...
Dillion Brian Grant Posted August 4, 2018 Share Posted August 4, 2018 I would like to know that as well i might look into making mine like that Quote Link to comment Share on other sites More sharing options...
TwistedCustoms Posted August 4, 2018 Share Posted August 4, 2018 Lots of them are made with a hardy shank, mine have a tab on bottom, 3/8" by 1 1/2" by 2" that I clamp in the post vise. You can also make a dedicated work station for them so you have all your dies in one place with the tool. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 4, 2018 Share Posted August 4, 2018 Mine has a shank to fit in the portable hole: (Note: This was an earlier version of the portable hole, where I hadn't yet added the 2.5" thick striking face. Since the latter has a smaller hardy hole, I had to cut the stem off the guillotine and weld on a new one.) Quote Link to comment Share on other sites More sharing options...
