Gary65 Posted January 15, 2018 Share Posted January 15, 2018 Hey people,Hoping for some feedback on the new torch I built. I've attached some photos in the hopes that someone could tell me if I need to (or not) do some tweaking.One is of it is with it lit with the gauge barely reading above 0. The other is it at 7 psi. The last is of the throat which is a reducer that is 3/4" x 1-1/2". The jet is 1/8" x 3" nipple with a #57 hole in a cap. I didn't do a water test to center the jet but I tend to have a good eye and centered it pretty well. I also slid the assembly in and out until the flame tried to go out (in both directions) and turned out the center of that created the perfect flame (at least that's what I think, you tell me). At start up with the gauge almost at 0, the flame huffs until i close the choke which is just the top of a tuna can cut out (yes, i watched A LOT of you tube). with the choke closed, it doesn't make any sound. With the choke off and the psi turned up to 7, it roars like a jet engine. From what i read and watch, it sound like i did OK.I accidentally got into this from taking a welding class and one of my projects was a branding iron. I got tired of holding the torch!Comments are greatly appreciated.! Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted January 15, 2018 Share Posted January 15, 2018 Yes, you need to do some tweaking. I suggest you start with page one and read clear through the Burners 101 thread on this forum. It's all very nice to design your own burner, but it helps out a lot to have some idea what you're doing. Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 15, 2018 Share Posted January 15, 2018 Flame is no where near perfect. Google search flame color to oxygen. You are running extremely rich. Issues. 1. Not enough oxygen. You need to drill intake holes. 2. Orifice is to large. #57 is .043 way to big. #68(biggest) to #76(smallest) i would recommend a #72. 3. Choke. I dont even see it in the photos. Either im blind or its someplace it realy shouldnt be. 4. Flare. 3/4 to 1 1/2 is i would say to large and will not provide a proper venturi to hold the flame. That said it seems to be working dine in the photo. However i think once its backpreasured by being in a forge it will not. If you start to experience blowouts or the flame collapsing back in to the burn tube swith to a 3/4 by 1 with the threading at the 1" side ground away. Quote Link to comment Share on other sites More sharing options...
Gary65 Posted January 15, 2018 Author Share Posted January 15, 2018 I don't have the choke on in the photo. My flare is 3/4" x 1" with the threads ground down. The intake is 3/4" x 1-1/2". I noticed the flame ignite's way down in the tube very close to the flare end. Where should I drill the intake holes? Quote Link to comment Share on other sites More sharing options...
Gary65 Posted February 6, 2018 Author Share Posted February 6, 2018 Ok. I read thru (as much as I could before my eyes crossed) burners 101. Man that's a lot of info! I now see that I should have come here before watching all the crazies on YouTube. I settled on the side arm burner and believe I built it as described. Parts I used; 1-1/4" T Bushing 9" x 3/4" tube (one end of the threads cut off) Flare from Larry. 1/8" x 5" (bought it long, I wasn't sure how much adjustment was needed). Schedule 80. .35 mig tip. My question is based on the attached photo. Generally how far into the T does the mig tip sit? I'm getting a much better flame thou. Quote Link to comment Share on other sites More sharing options...
