coops1911 Posted January 2, 2018 Share Posted January 2, 2018 Building my first forge and see on here the go to type of coating over ceramic fibre is kastolite-30. I ended up ordering this https://www.psh.ca/index.php?item_id=RMOR3 thinking it will work fine as a 1/2" layer over 2" of ridigized ceramic wool. but now I'm getting the impression that castable and refractory mortar have different uses? so what do you guys think, will this product work or is it not even worth using? many thanks Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 2, 2018 Share Posted January 2, 2018 Guessing by the description of "sticking bricks together" you have a refractory cement. That is used to hold refractory (like fire bricks) together. It can not handle direct flame contact and will crumble crack and fall away. You need a hard refractory (kastolite 30/misou) not a refractory cement. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted January 2, 2018 Share Posted January 2, 2018 2 hours ago, coops1911 said: but now I'm getting the impression that castable and refractory mortar have different uses? so what do you guys think, will this product work or is it not even worth using? They do have different uses. If you have not already coated the blanket I would recommend getting the right material. Kastolite 30 works well in this application. If you have already used the cement you may want to try it out, but don't expect it to last long. Quote Link to comment Share on other sites More sharing options...
coops1911 Posted January 2, 2018 Author Share Posted January 2, 2018 no haven't got that far yet so I can switch it up. thanks Quote Link to comment Share on other sites More sharing options...
coops1911 Posted January 3, 2018 Author Share Posted January 3, 2018 ordered the proper stuff from Wayne , want to do it right the first time. Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted January 3, 2018 Share Posted January 3, 2018 Thanks Coop, I'll get it right out. Thank you Wayne. Quote Link to comment Share on other sites More sharing options...
