MotoMike Posted December 31, 2017 Share Posted December 31, 2017 My buddy wants to turn this into a pry bar. It is marked "drop forged". is it tool steel? How would you work it? what color for the initial working? after working anneal it? re harden it? Temper it? to what color? thanks in advance Mike Link to comment Share on other sites More sharing options...
Michael Cochran Posted December 31, 2017 Share Posted December 31, 2017 Your hardening and tempering process will be a hit or miss kind of thing. Using scrap or mystery steel you need to cut off a couple of test “coupons” so that you can test your quench and temper to find a good setup. I cannot help with working temps or steel type. I can only assume that it might be a tough steel but I could be a cheap steel masquerading as a good steel. This is why the suggestion of using good/new/known steel is so prevalent here on IFI. Link to comment Share on other sites More sharing options...
MotoMike Posted December 31, 2017 Author Share Posted December 31, 2017 Thanks Michael. I'll share all this with my buddy. If I cut off the hooks think it would be enough to make the test pieces? Link to comment Share on other sites More sharing options...
Michael Cochran Posted December 31, 2017 Share Posted December 31, 2017 That would probably be what I’d do if I didn’t plan to use them in my forging. Cut them off and forge them long and flat. You might want to try a graduated temper after you quench to see what colors you might want for tempering. Remember to try air quench then oil and lastly water. If it doesn’t harden or doesn’t harden enough you might try the next step to see if it’s better. Link to comment Share on other sites More sharing options...
JustAnotherViking Posted December 31, 2017 Share Posted December 31, 2017 I assume this is just an exercise in experimenting with the steel rather than trying to save cash? I would imagine just buying a new purpose made pry bar would be more cost effective than the time and fuel involved in trying to modify a perfectly good tool Link to comment Share on other sites More sharing options...
MotoMike Posted January 1, 2018 Author Share Posted January 1, 2018 Thanks Michael correct viking Link to comment Share on other sites More sharing options...
Judson Yaggy Posted January 1, 2018 Share Posted January 1, 2018 I find the cheap Chinese crowbars tend to work like 1045 or 1050. YMMV. Start from there and experiment, and don't assume they are all made of the same stuff. Link to comment Share on other sites More sharing options...
Frosty Posted January 1, 2018 Share Posted January 1, 2018 It's a pry bar now disguised as a nail puller. Test coupons first. I'd treat it like medium carbon steel. When you're testing the coupons take notes! Frosty The Lucky. Link to comment Share on other sites More sharing options...
MotoMike Posted January 29, 2018 Author Share Posted January 29, 2018 Thanks Frosty and Judson Link to comment Share on other sites More sharing options...
Please sign in to comment
