Tubalcain2 Posted December 27, 2017 Share Posted December 27, 2017 OK, I just managed to stab myself in the face with a flying 1000deg. knife. Yup. I was working it too cold and it flipped out of my locking pliers and into my nose. Penetrated to just inside my nostril, maybe 3/8 of an inch or so. I am SUPER thankful it was not 2 in. higher or I would be an eye short right now. Moral of the story? Don't work your steel cold, and use the proper tool for holding your stock. Locking pliers are great, but they are not for all stock shapes. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted December 27, 2017 Share Posted December 27, 2017 Ouch. Yeah lucky it was not worse. Locking pliers also can loosen up with hits and jarring around. Time to make or invest in some proper tongs for the job. Quote Link to comment Share on other sites More sharing options...
JustAnotherViking Posted December 27, 2017 Share Posted December 27, 2017 Ouch! I assume you're either stitched back up or sporting a nice nose ring at this point? Silver lining and all that Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted December 27, 2017 Author Share Posted December 27, 2017 1 hour ago, Daswulf said: Ouch. Yeah lucky it was not worse. Locking pliers also can loosen up with hits and jarring around. yup. more/better tong stock is on the list. 1 hour ago, JustAnotherViking said: Ouch! I assume you're either stitched back up or sporting a nice nose ring at this point? No, i'm letting it heal naturally. We try to avoid the medical system as much as possible. Quote Link to comment Share on other sites More sharing options...
Stash Posted December 27, 2017 Share Posted December 27, 2017 Now, I'm assuming you had your eye protection on...... Steve Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted December 27, 2017 Author Share Posted December 27, 2017 No, I have not been in the habit of "glassing up" when I forge. That has definitely changed. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted December 28, 2017 Share Posted December 28, 2017 I ran across these this evening while looking through my resource piles. Just in case you see these at HF and think " oh, those will work great for forging" No They Don't! They continually open a bit using them as you hammer the stock. The picture is as closed as they get now and they only got worse as I had used them years ago. Junky and dangerous. Just a public service announcement from a past failure. Oh yeah, WEAR YOUR SAFETY GLASSES! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 3, 2018 Share Posted January 3, 2018 I learned the cold steel part from holding tongs between my legs while using hammer and tooling on the stock. It will let you know when the plasticity goes down. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted January 3, 2018 Share Posted January 3, 2018 Water pump/Chanellock pliers work better as adhauk tongs than vice grips ever have Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 3, 2018 Share Posted January 3, 2018 1 hour ago, ThomasPowers said: I learned the cold steel part from holding tongs between my legs while using hammer and tooling on the stock. It will let you know when the plasticity goes down. You ARE talking about the plasticity of the steel. Yes? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
