Jclonts82 Posted December 20, 2017 Share Posted December 20, 2017 I'm currently working on a new forge build, old (first) one has become a little bit on the small side for some projects I'm wanting to work on. I do a fair bit of pattern welding, so higher temperatures. I'm using Kast-o-lite 30 for the first time, and want to know how thin CAN you go with it. I know WayneCo uses 1/2", as does pretty much everyone else (then its probably for a good reason right?) when coating rigidized ceramic wool. I'm just curious if 3/8 inch, or 1/4 inch would work or not. Is the 1/2 thickness needed for strength? heat retention properties (not letting too much heat get to the wool)? something else I have no idea about? I'm going to finish coat with ITC-100, I would buy new matrikote or plistex, but I obtained free ITC-100 from the local community college's ceramics guy; it 'expired' and would have just been thrown away so I'm using that. He said it had been on the shelf for ~2years and never opened. It is still quite wet, so I figured why not? Any thoughts on the matter would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted December 21, 2017 Share Posted December 21, 2017 I have always cast about 1/2" thick just because of the space between the blanket and the edge of the door and it has always worked well. I see no reason that 3/18" would not work well and may be even 1/4" . 3/16" seems a little bit thin but try it and let me know how well it lasts. If I had free iTc-100 I would use it too! Let me know if I can help you. Wayne Quote Link to comment Share on other sites More sharing options...
Jasent Posted December 21, 2017 Share Posted December 21, 2017 I've done kastolite 1/4" and it has held up nicely. Bout 4 months now. Floor is 1/2" the rest is closer to 1/4-3/8 Quote Link to comment Share on other sites More sharing options...
