Glenn Posted December 5, 2017 Share Posted December 5, 2017 Used to be you could just grab a wooden pallet and use or reuse it as a pallet, or tear it down to the slats and rails and use the lumber for other projects or as kindling to start a fire. Not any more. There is the logo of the International Plant Protection Convention (IPPC) and is stamped on the wood of the pallet. IPPC pallets are used for international shipping and require require pallets constructed using raw wood to be treated and to be made of a material that will not carry invasive insect species or plant diseases through different countries. Officially approved agencies supervise pallet treatment methods. There are other markings beside the logo that you want to look for. [HT]: Wooden pallets manufactured in Canada or the US undergo a pest control treatment called heat treating (HT) which involves heating the pallet to a minimum core temperature of 56°C (133° F) for softwoods and 60°C (140° F) for hardwoods for a minimum of 30 minutes in a kiln. HT pallets are not harmful to your health. [KD]: The purpose of kiln-dried lumber is to reduce the moisture content of the wood (19% or less). This is a means to control warping, fungal growth, and other quality features. The kilns or ovens used to dry the wood do not necessarily reach the sustained temperature of 133 degrees Fahrenheit (56 Celsius) that would qualify as heat treated. Many lumber mills are processing their timber to meet the heat treatment requirements; thus you will see “KD-HT” incorporated in the wood grade stamp. With cherry and oak wood, the curing temperature causes releases sap from within the wood. Sap coats the wood with a dark stain, making the pallets or crates appear old and worn. The heat treating process does not compromise the strength and durability of pallets and containers. KD pallets are not harmful to your health. [DH]: New, used, previously assembled, repaired, or re-manufactured wood packaging material is heat treatment using dielectric heating. [DB]: These two letters indicate that the pallet is debarked according to IPPC regulations. Many pallets have this stamp. It does not matter if your pallet has this stamp or not. Many pallets do not have it. The process of “debarking” wood is to remove the bark (rough outer layers of wood) using a cutting tool or a planer, and the pallet wood remains untreated. This procedure is done to allow for a more thorough treatment of wood before being approved for transport (aside from smoothing the wood). Pallets marked with the letters DB only are chemical-free and safe to use. Newer pallets no longer require this stamp by the IPPC, as most modern wood treatment procedures require “debarking” as a standard part of their process. Avoid “HIGHLY TOXIC” pallets! MB pallets. They are not Safe! [MB]: Methyl bromide (Bromomethane) fumigation, this is a potent pesticide linked to human health problems and ozone layer depletion. Methyl bromide fumigation kills invasive species like pine beetles. In 1987, the Montreal Protocol aimed to regulate the use of methyl bromide, along with multiple other chemicals found to impact the ozone. This type of treatment is now banned in Canada and many countries because it poses health risks to workers handling the pallets. However, you can still find it in some places. If you find an MB pallet (likely from Asia or Oceania), do not use it for your craft projects or as firewood, find a waste-removal company that can dispose of it properly. MB pallets are not Safe! Reference Toxipedia, Methyl bromide Methyl bromide is a broad spectrum pesticide used to control pest insects, nematodes, weeds, pathogens, and rodents. In the U.S., methyl bromide has been used in agriculture, primarily for soil fumigation, as well as for commodity and quarantine treatment, and structural fumigation. Methyl bromide can enter the body through inhalation by breathing air contaminated with methyl bromides, through the skin or the eyes. The symptoms of inhalation of methyl bromide are abdominal pain. convulsions, dizziness, headache, labored breathing, vomiting, weakness, hallucinations, loss of speech and in-coordination When skin comes in contact with methyl bromide, it can cause itching, burning, and tingling. Skin absorbs methyl bromide and it causes the following symptoms redness, burning sensation ,pain and blisters When methyl bromide comes in contact with eyes, the symptoms are redness, pain, blurred vision, temporary loss of vision The EPA lists methyl bromide as “highly acute toxic“! Methyl bromide has not been used since 2005 in most countries, but there are still old pallets in circulation. References: IPPC, IPPC WHO, Wood Packaging for Export, FAO UN, FAO UN2 CFIA, Pallets. Toxipedia, Biological Invasions, Plant Quarantine, ISPM 20 Guidelines, Methyl bromide, Bromomethane, Methyl bromide 2, ATSDR-MMG, and others Link to comment Share on other sites More sharing options...
JHCC Posted December 5, 2017 Share Posted December 5, 2017 This is only about the pallets themselves. It doesn’t address whatever toxic nasties may have spilled on them in some warehouse. Link to comment Share on other sites More sharing options...
Glenn Posted December 5, 2017 Author Share Posted December 5, 2017 You are correct. Thank you for adding that. The scary part is here is no way of knowing what was spilled on and absorbed into the wood. The list of those contaminants could include anything. It is not where you got the pallet, but how many times the pallet was used before it got to you. This is one reason NOT to use pallet wood for any project indoors or where food, children, etc is involved. Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 5, 2017 Share Posted December 5, 2017 For folks of a certain age: Anybody remember that issue of Mother Earth News that had an article about how to build kitchen cabinets from old ammo crates? Followed the next? month with an article saying DON'T DO THAT!!!!!!!!! The old VietNam era ammo crates were heavily treated to resist rotting and fungi attack for something like years of ground contact in Nam...you shouldn't sand, cut or otherwise process them without heavy duty safety equipment and any sawdust was considered Hazardous Waste! I've seen smiths use ammo crates for tool boxes and would NOT recommend it! Link to comment Share on other sites More sharing options...
JHCC Posted December 5, 2017 Share Posted December 5, 2017 If you use ammo crates for firewood, make sure they’re empty first! Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 5, 2017 Share Posted December 5, 2017 How about when using shells for an anvil or cone mandrel? Link to comment Share on other sites More sharing options...
JHCC Posted December 5, 2017 Share Posted December 5, 2017 That could take your ring making to new heights. Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 5, 2017 Share Posted December 5, 2017 Sure to attract a crowd after the demo ends... Link to comment Share on other sites More sharing options...
JHCC Posted December 5, 2017 Share Posted December 5, 2017 ABANA forbids anvil shooting, but I don't know if they say anything about putting your mandrel in orbit. Link to comment Share on other sites More sharing options...
Please sign in to comment
