Frank1967 Posted November 16, 2017 Share Posted November 16, 2017 Looking for any information on my grandfather's anvil. Can't make out the name for sure but I can send pics if anyone knows anything about this anvil. Can't find any info on the web. Thanks Link to comment Share on other sites More sharing options...
arftist Posted November 17, 2017 Share Posted November 17, 2017 I can't tell either. If I had to guess though, I' d say it is a Fisher made in 1896. Darned good anvil if it isn't beat up too bad. can't tell that either. Link to comment Share on other sites More sharing options...
njanvilman Posted November 17, 2017 Share Posted November 17, 2017 17 hours ago, Frank1967 said: Looking for any information on my grandfather's anvil. Can't make out the name for sure but I can send pics if anyone knows anything about this anvil. Can't find any info on the web. Thanks Adding pictures would make all the difference in the world. Link to comment Share on other sites More sharing options...
Steve Sells Posted November 17, 2017 Share Posted November 17, 2017 Does it look like this one ? Link to comment Share on other sites More sharing options...
Frank1967 Posted November 17, 2017 Author Share Posted November 17, 2017 3 hours ago, Steve Sells said: Does it look like this one ? If you posted a picture Steve it didn't show up but I posted pictures of the one i have Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 17, 2017 Share Posted November 17, 2017 Fisher, cast iron body, steel face, the date was put on as they had a warranty period. Don't know where you are at but there is a Fisher Museum on the United States east coast and it's proprietor is on this form as well: NJanvilman Link to comment Share on other sites More sharing options...
njanvilman Posted November 18, 2017 Share Posted November 18, 2017 Fisher anvil, made in 1896, in Trenton, NJ. Rough shape: missing mounting lugs, the steel plate originally on the horn, the back part of the anvil from the hardy hole. The anvil obviously had a very hard life. But I am sure lots of things got made and repaired using it. Since the anvil has a family history, to you it is priceless. I would make a brass tag and stamp in its provenance and glue it to the anvil. History is often forgotten over the generations. Link to comment Share on other sites More sharing options...
Frank1967 Posted November 19, 2017 Author Share Posted November 19, 2017 Thank you for the information. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 19, 2017 Share Posted November 19, 2017 Welcome to IFI Frank, Be sure to "toll the anvil" three times every time you enter the shop to honor your Grandfather and all the work that was done on it. I'm sure there is a lot of life left in it for light work. If you will edit your profile to show your location, you may be surprised how many of the gang are close to you and a lot of answers are location dependent. Link to comment Share on other sites More sharing options...
Scott G. Posted March 28, 2019 Share Posted March 28, 2019 My brother in law dug an anvil out of his scrap iron pile and gave it to me. After I removed most of the rust it had the same SHEA cast into the base with a date of 1923. It has a more conventional shape to it, and has had some hard use. It also has some vertical marks cast into the base at the back. I'm wondering if these are an indication of its weight. Link to comment Share on other sites More sharing options...
Lou L Posted March 28, 2019 Share Posted March 28, 2019 Welcome to IFI, Scott! If it has similar stamping it is likely a Fisher as well, but others know much more than I do. I doubt the lines have anything to do with weight, however. If you post a picture you will get all the answers that can be had about your anvil. Also, check out this post right away so you can get the most out of this forum: Lou Link to comment Share on other sites More sharing options...
Please sign in to comment
