Dan P. Posted November 10, 2017 Share Posted November 10, 2017 I've just got my hands on an old mechanical hammer. All the main bearings are fitted with grease nipples. On a different, and very very old hammer, all the main bearings were fitted with wick oilers/cups. Grease always seemed to me a nice thing to catch and trap dust, grit, soot and other nasties. Is there consensus on whether oil or grease is better on particular bearings? Or all? The late, great G. Sarver says, somewhere on these forums, 30wt oil for everything, and he was a man who new what he was about. Your thoughts, hints, tips…? Quote Link to comment Share on other sites More sharing options...
JeepinJoe Posted November 10, 2017 Share Posted November 10, 2017 There is a triple zero "000" grade of grease that is like a thick oil that you can use in a grease gun. It's used for dusty and gritty environments. Just as you mentioned a heavy grease will catch all of the dust and grit and it is stuck there forever. It is used mostly in commercial applications so it is hard to get in smaller quantities. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted November 11, 2017 Share Posted November 11, 2017 Depends on the type of bearings. Ball & roller bearings require grease while babbit bearings require heavy oil. What type of hammer do you have (pictures would help). Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted November 11, 2017 Share Posted November 11, 2017 Good Morning, Chainsaw Bar Oil works very well. You don't need a lot, it still lubricates. Neil Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted November 11, 2017 Share Posted November 11, 2017 20 minutes ago, swedefiddle said: Good Morning, Chainsaw Bar Oil works very well. You don't need a lot, it still lubricates. Neil Yep... I add a little STP to it. Quote Link to comment Share on other sites More sharing options...
beaudry Posted November 11, 2017 Share Posted November 11, 2017 Vactra 2 way oil is designed for heavy pressure and slow speeds [lathe and milling machine beds for example ] Works great for most open flow through type bearings commonly found on mechanical power hammers . It's relatively cheap and is available in gallons or 5 gallon pails from most industrial supply houses. Not as sticky as bar oil so it doesn't hold the grit and dirt . Use lots, to keep things running smoothly and flush out the dirt. Oil is always cheaper than parts or downtime. If the hammer has grease fittings or grease cups use a light grease suitable for heavy loads, slow speeds . Quote Link to comment Share on other sites More sharing options...
Dan P. Posted November 13, 2017 Author Share Posted November 13, 2017 Thanks a lot for the answers! The hammer is a Massey. It has slide ways similar to a Pattinson or Platt or "new style" Little Giant. I haven't had a look at the bearings yet but I would happily put money on them being plain bearings. I am looking at this type of grease for the main shaft bearings and pitman; https://www.onlinebearings.co.uk/Lithium-Autolube-EP-000-Grease-12.5kg.html And a 30wt gear/transmission oil for the slides. Thanks for the input. Quote Link to comment Share on other sites More sharing options...
