BeaverNZ Posted November 9, 2017 Share Posted November 9, 2017 I am at the point of the final finishing of my blade and I am torn which way to put the edge on my blade, its all heat treated and almost as polished as its going to get before etching but I am wondering on how to stop the distal taper from affecting the width of the bevel. All the beveling that i have seen on youtube have been quite thick blades and parallal my blade at the thickest where the bevel will start is about 2.6mm down to about 0.9mm at the point. If I use a diamond imbeded flat cutter and a Heim/rose joint set at the correct height and point or maybe one of those little finger belt sandes/power files guided by the same means I have alot of time in this now and dont want to stuff it any suggestions would be good thanks Beaver Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 9, 2017 Share Posted November 9, 2017 Well all the professional knifemakers I know hold the blade in the hands and use the belt grinder and mad grinding skills to do the final beveling. Before heat treat you can draw file it close. You are sounding like a machinist, are you one? Link to comment Share on other sites More sharing options...
BeaverNZ Posted November 9, 2017 Author Share Posted November 9, 2017 Hello Thomas Hmmm I thought someone might say freehand and thats probably what will happen and my officail work title is a fitter welder A so i have a foot in each camp welding and machining and now Im doing my best to add forging which is a lot different in how you think about how to make things, Volume instead of size. I think it may be time to bite the bullet and make my smaller variable speed linisher that I have been thinking about for ages Cheers Beaver Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted November 10, 2017 Share Posted November 10, 2017 Google knife bevel filing jigs. One can tread the rod and screw your 4" to it to rough in your angles, then file them befor switching to stones. Diamond stones and files are nice for hardened stock Link to comment Share on other sites More sharing options...
Please sign in to comment
