Will42805 Posted May 20, 2018 Author Share Posted May 20, 2018 20180520_140442.mp4 Well there it is. Think i still got some burner tuning to do. How hot should the burner tubes get. Mine are hot to the touch I think it's burning up inside and they may be a bit long. Link to comment Share on other sites More sharing options...
Will42805 Posted May 21, 2018 Author Share Posted May 21, 2018 About two or three hours after this video I went out and relit it. This time the burner seem to be functioning much better. They're burning down inside the forge very clearly. And the burners don't seem to be smoking nearly as much. I'll play around with it a little bit more later today. And I will get some pictures Link to comment Share on other sites More sharing options...
Mikey98118 Posted May 21, 2018 Share Posted May 21, 2018 I think your exhhaust opening is too small; that wioll choke burner performance. I also think that your forge needs to dry out more. Link to comment Share on other sites More sharing options...
Will42805 Posted May 21, 2018 Author Share Posted May 21, 2018 I do think the opening may be too small due to the fact that the burners seem to be pulsing. The burners no longer heat up though and seem to be burning down inside just fine. I do plan on maybe doming the top of the opening so that I may get other things in and have a little more room. I've only been running it for 5 to 10 minutes at a time to bake out any excess water. Link to comment Share on other sites More sharing options...
Mikey98118 Posted May 21, 2018 Share Posted May 21, 2018 If you double the height of your exhaust opening, then you can use brick in front of it (not right next to the opening) to allow exactly the right amount of exhaust for whatever input you run the burners at, while reflecting most radiant heat back into the forge. Link to comment Share on other sites More sharing options...
Please sign in to comment
