Glenn Posted March 23, 2008 Share Posted March 23, 2008 Someone please explain the difference between penetration and fusion in welding. Many times I hear "good penetration" but not so often the term fusion of the welded metals. Quote Link to comment Share on other sites More sharing options...
Rutterbush Posted March 23, 2008 Share Posted March 23, 2008 Handbook - Welding Techniques This says it so much better than I canHandbook - Weld Defects Quote Link to comment Share on other sites More sharing options...
Dodge Posted March 23, 2008 Share Posted March 23, 2008 Fusion is what happens when a proper weld is made. The metals fuse together. Penetration is how deep in the weld joint or groove the fusion takes place. If your weld is fused all the way through the parent metals (the two pieces being joined) you have 100% penetration. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted March 23, 2008 Share Posted March 23, 2008 Like Scott sez, fusion welding is the process. Full thickness penetration welds ( 100% welds ) are made by proper prep ( small gap, weld a root, go to other side, back grind into the root or gouge and grind and make a pass). Back grind if necessary( or use a needle scaler) and continue with stringer passes until the cavity is full ( and a smidge over with no undercut or under fill ). Do the same on other side. Full penetration weld that should xray and or bend/hydro test to pass for the man. These welds I speak of are often made with either solid wire or FCAW and perhaps cap gas as well ( outside in the wind ). The welder has enough responsibility to cure any porosity or hole issues immediately but they do not happen often. This is used on carbon or stainless 10 guage to 1" + thick. Tank heads to man ways to legs to inside baffles. Thank you Rutterbush for the links. Quote Link to comment Share on other sites More sharing options...
