CrookedBlade Posted October 11, 2017 Share Posted October 11, 2017 So, im a learning blacksmith and im about to build the first my own forge, i was thinking layering a baking pan with some clay and then putting some firebricks for the walls, and a straight steel pipe with a crack cut in and a 1600 watt hairdryer for the air source. Would it work? Quote Link to comment Share on other sites More sharing options...
jeremy k Posted October 11, 2017 Share Posted October 11, 2017 Have you read the many threads about building a forge in the forge section of the forums here on Iforgeiron? Quote Link to comment Share on other sites More sharing options...
CrookedBlade Posted October 11, 2017 Author Share Posted October 11, 2017 I have read some. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 11, 2017 Share Posted October 11, 2017 Work for what? Using what fuel? "Some Firebricks": is that enough, too many or not enough? Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted October 11, 2017 Share Posted October 11, 2017 1 hour ago, CrookedBlade said: I have read some. then you will know most of it. a lot is location dependent, someone in the islands to the north of me will be testing peat as a forge fuel, his grandfather had a peat forge in the same type of forge we use for coal / coke / charcoal but that is not like your forge and I dont know what fuels you can get in the antartic / sahara / celon / china / or where ever you are also what do you intend to work jewelery? or making large anvils? it may work or it may not depending on what you have not told us Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted October 11, 2017 Share Posted October 11, 2017 For simplicities sake a side blast with the 3/4-1" ID tuyere and the native mineral soil in a box 8" deep will get you started. Quote Link to comment Share on other sites More sharing options...
