Derek Haiges Posted October 4, 2017 Share Posted October 4, 2017 In terms of quieting an anvil, has anyone attempted to spray multiple coats of rubber on the underside? And or any reasons not to. My thinking behind this is that if sound is vibration, would rubber absorb some of the vibrations quieting the anvil? Quote Link to comment Share on other sites More sharing options...
JHCC Posted October 4, 2017 Share Posted October 4, 2017 Are you asking about between the anvil and its stand? Or on the non-working surfaces of the anvil that are still exposed to the light of day? In the former case, there are better options available (e.g., silicone caulk); in the latter, the minute something hot hits it (and it will. Oh, it will), it ain't gonna be smelling so good. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 4, 2017 Share Posted October 4, 2017 You've been watching too much TV I see. I don't know of anybody trying that trick, it might work let us know please. Some guys use silicone calking and like the results, spray on rubber seems like about the same thing to me but I quiet my anvils entirely differently. I make steel tripod stands with an angle iron rim the anvil's foot JUST slips into. The anvil is secured with angle iron tong and hammer racks that wedge between the anvil's foot and the rim. The difference in resonance between the anvils and the stands damps the ring to a clink rather than ear piercing ring. On a wood block stand the Trenton is unpleasantly loud and the Soderfors will make your ears ring through plugs and muffs. The steel stand took the pain out of both and they still have a nice anvil ring so spectators know I'm really blacksmithing. Go ahead and laugh but at demos the audience WANTS to hear an anvil sound like an anvil without injuring them. It's part of the theater or demonstrations. I know that was a long rambly post but I can't think of a reason not to try your spray rubber. Be sure to give it time to dry, set, cure, whatever it does to stop being spray on goop and turn into rubber or it'll glue your anvil to the stand. Of course if you want to glue your anvil to the stand, install your anvil before the rubber cures. In that case, I think I'd think spray each, let it set then spray one and install the anvil before the rubber sets to GLUE IT IN THE STAND. Please keep us in the loop this might be THE thing to quiet anvils. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Charcold Posted October 4, 2017 Share Posted October 4, 2017 I vaguely remember reading someone said they used a rubber mat under their anvil when i was researching styles of stands, but i cant recall results or if this was somehow connected to the anvil or simply sitting under it. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted October 4, 2017 Share Posted October 4, 2017 I have rubber mat under two of my anvils that are on steel stands and it seems to help fine in deadning the ring just a little more. Doesn't need to be thick rubber mat. Quote Link to comment Share on other sites More sharing options...
Derek Haiges Posted October 4, 2017 Author Share Posted October 4, 2017 Basically i would flip anvil upside down and spray everything exposed. So not the face or maybe an inch away from the face so it doesnt melt being so close. Quote Link to comment Share on other sites More sharing options...
