Jim Coke Posted October 2, 2017 Share Posted October 2, 2017 Greetings all, I thought I would share a simple hold down that I designed... Works great for flat or round stock.. The offset design allows for longer stock .. Its a super beginner project and you will find it's your go to tool for many projects.. Have fun. comments suggestion welcome .. Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
JerryCarroll Posted October 3, 2017 Share Posted October 3, 2017 Good design! I gotta weld the extra finger on mine. I just bent the hold down end over but it works pretty good. Quote Link to comment Share on other sites More sharing options...
Dylan Sawicki Posted October 3, 2017 Share Posted October 3, 2017 Yup I'm gonna make one as soon as I can! Great design. Quote Link to comment Share on other sites More sharing options...
JHCC Posted October 3, 2017 Share Posted October 3, 2017 I've got to say, this is beautiful and I love the look, but I've been having a lot of trouble getting my hammered-in hold-downs to stay put. They just keep popping out under load, which is annoying as all get-out. So far, I've been a lot happier since I switched to the motorcycle chain hold-down. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 3, 2017 Share Posted October 3, 2017 Me; I found the top jaw of a largish pipewrench alongside the road. (When we carpooled to the SOFA meetings the gang got used to the "STOP there's a piece of metal on the side of the road...) I forged it to fit my hardy hole and drilled a hole in the shaft and welded a T handle on the top of it. When I need it I drop it in the hardy and hook a chain with a spring on it into the hole I drilled with the other end mounted to the base of the anvil stand. To use pull up on the T handle and insert the steel between the jaw and the anvil. Since you can remove the jaw and rotate it in 90 deg increments you can work with long pieces too by putting it to the side. Quote Link to comment Share on other sites More sharing options...
