bubba682 Posted November 5, 2017 Share Posted November 5, 2017 Sounds pretty scientific there Beaver lol basicically i'll be tig ing the first pass then i'll be puttin a couple of passes of stick over it and just weld er out. Im not worried about speed i want good fusion for the first pass.I'll make up for speed with the stick its just basic welding theres no special procedure for welding that frame.If i had a deeper penetrating mig i'd use that after i tigged it but all i got is a 220v/170 amp mig i wouldnt trust it for the press and hydraulics it just doesn't have the ability for penetration and fusion required.We always preheat in Canada its cold up here i don't need any micro cracks forming in the weld because of moisture that could lead to a catastrophic failure.Low hydrogen rods dont like moisture now if i run 6011 for a first pass i might get away without a preheat as long as air temp is above freezing.Personally i prefer heating it up to 250/300 degrees to me it makes for a better weld, up here most high pressure pipe precedures require it depending on air temp for example.So when it gets cold, out come the tiger torches for small bore and chicklets for the big stuff. Alot of the certified plate shops up here sweat it out to 250 degree before its welded .Anyway thats how i do it and so far so good passed alot of xrays and made some good cash over the years. Oh and Kev she looks good buddy what steel did you make the pins from. . Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 6, 2017 Author Share Posted November 6, 2017 This thing is going on wheels just over 6 foot and 28” wide it’ll just go through my door . I don’t know if this motor pump setup will be ok got it off eBay the other day 3.7 kw 5hp 8gpm Hilo pump £200 should be able to give it a try by the end of the week with a bit of luck thanks for your comments On 05/11/2017 at 12:17 AM, bubba682 said: Sounds pretty scientific there Beaver lol basicically i'll be tig ing the first pass then i'll be puttin a couple of passes of stick over it and just weld er out. Im not worried about speed i want good fusion for the first pass.I'll make up for speed with the stick its just basic welding theres no special procedure for welding that frame.If i had a deeper penetrating mig i'd use that after i tigged it but all i got is a 220v/170 amp mig i wouldnt trust it for the press and hydraulics it just doesn't have the ability for penetration and fusion required.We always preheat in Canada its cold up here i don't need any micro cracks forming in the weld because of moisture that could lead to a catastrophic failure.Low hydrogen rods dont like moisture now if i run 6011 for a first pass i might get away without a preheat as long as air temp is above freezing.Personally i prefer heating it up to 250/300 degrees to me it makes for a better weld, up here most high pressure pipe precedures require it depending on air temp for example.So when it gets cold, out come the tiger torches for small bore and chicklets for the big stuff. Alot of the certified plate shops up here sweat it out to 250 degree before its welded .Anyway thats how i do it and so far so good passed alot of xrays and made some good cash over the years. Oh and Kev she looks good buddy what steel did you make the pins from. . The bottom pin is 41 mm h13 and the top pin is 65mm I think 24t I don’t know what the equivalent will be in Canada but the guy at the steel place so that would be plenty strong enough we Shall see I think I will take them out after I have had a go with it just to make sure they’re okay Quote Link to comment Share on other sites More sharing options...
bubba682 Posted November 7, 2017 Share Posted November 7, 2017 Shes comin along nicely i'm going to have to source the pins i got a 3'' ram from an excavater cyl i i was thinking of getting turned for pins but im not sure on the strengh. The only to i really got left to get is the pins and get the plate punched for the pins.Theres a hydrolic shop i deal with im sure they;ll have them, i hope. Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 10, 2017 Author Share Posted November 10, 2017 On 05/11/2017 at 12:17 AM, bubba682 said: Sounds pretty scientific there Beaver lol basicically i'll be tig ing the first pass then i'll be puttin a couple of passes of stick over it and just weld er out. Im not worried about speed i want good fusion for the first pass.I'll make up for speed with the stick its just basic welding theres no special procedure for welding that frame.If i had a deeper penetrating mig i'd use that after i tigged it but all i got is a 220v/170 amp mig i wouldnt trust it for the press and hydraulics it just doesn't have the ability for penetration and fusion required.We always preheat in Canada its cold up here i don't need any micro cracks forming in the weld because of moisture that could lead to a catastrophic failure.Low hydrogen rods dont like moisture now if i run 6011 for a first pass i might get away without a preheat as long as air temp is above freezing.Personally i prefer heating it up to 250/300 degrees to me it makes for a better weld, up here most high pressure pipe precedures require it depending on air temp for example.So when it gets cold, out come the tiger torches for small bore and chicklets for the big stuff. Alot of the certified plate shops up here sweat it out to 250 degree before its welded .Anyway thats how i do it and so far so good passed alot of xrays and made some good cash over the years. Oh and Kev she looks good buddy what steel did you make the pins from. . The bottom pin is 41 mm h13 and the top pin is 65mm I think 24t I don’t know what the equivalent will be in Canada but the guy at the steel place so that would be plenty strong enough we Shall see I think I will take them out after I have had a go with it just to make sure they’re okay Quote Link to comment Share on other sites More sharing options...
BeaverNZ Posted November 10, 2017 Share Posted November 10, 2017 Very nicely finished Congrats Cheers Beaver Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 10, 2017 Author Share Posted November 10, 2017 1 hour ago, BeaverNZ said: Very nicely finished Congrats Cheers Beaver Thanks almost done just a few bits and I’ll fire it up Quote Link to comment Share on other sites More sharing options...
bubba682 Posted November 10, 2017 Share Posted November 10, 2017 She sure is purdy there Kev by put up a few pics when ya get her goin squeezen some steel. Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 10, 2017 Author Share Posted November 10, 2017 2 hours ago, bubba682 said: She sure is purdy there Kev by put up a few pics when ya get her goin squeezen some steel. Cheers I will I’ll see if I can put a link to a vid on YouTube Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 12, 2017 Author Share Posted November 12, 2017 Well I fired the press up I was pushing 3200 psi and a tad over a inch per second I don’t know what that means in tons can any one tell me cheers Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted November 12, 2017 Share Posted November 12, 2017 Devide the PSi (pounds per square inch) buy the piston size in square inch (PI R squared) and devide buy 2000 to get tons of force for youer piston size. Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 13, 2017 Share Posted November 13, 2017 1 hour ago, Charles R. Stevens said: Devide the PSi (pounds per square inch) buy the piston size in square inch (PI R squared) and devide buy 2000 to get tons of force for youer piston size. That's multiply psi x piston area sq/in, not divide. It's easy to get something backwards writing out equations in text. I HATED word problems in math. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted November 13, 2017 Share Posted November 13, 2017 Na, got it mixed up in my head befor I even started typing. I got to ground pressure and hydrolic force mixed up. Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 14, 2017 Author Share Posted November 14, 2017 Thanks for your replies I think i must be dumb I can’t work it out the. I keep getting the wrong answer internal diameter of the cylinder is 5 inches it as an 8 inch stroke and the rod is 2 3/8 60 mm and 3000 psi It would be very much appreciated if somebody could work this out for me as it is giving me an headache thanks Quote Link to comment Share on other sites More sharing options...
Latticino Posted November 14, 2017 Share Posted November 14, 2017 Cylinder crossection area= pi * D * D/4 = 3.14 x 5 x 5 / 4 = 19.64 square inches Force exerted = pressure x crossection area = 3000 x 19.64 = 58,905 lbs. Unit conversion: 58,905 lbs / 2000 lbs/ton = 29.4 tons Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 14, 2017 Author Share Posted November 14, 2017 4 hours ago, Latticino said: Cylinder crossection area= pi * D * D/4 = 3.14 x 5 x 5 / 4 = 19.64 square inches Force exerted = pressure x crossection area = 3000 x 19.64 = 58,905 lbs. Unit conversion: 58,905 lbs / 2000 lbs/ton = 29.4 tons Many thanks i didn’t think It would be that much but thanks I’ll get my forge going in the week and see if I can make myself a Hammer, cheers Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 14, 2017 Share Posted November 14, 2017 Suggest you make a hammer for yourself instead; very messy making yourself into one... Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 14, 2017 Author Share Posted November 14, 2017 18 minutes ago, ThomasPowers said: Suggest you make a hammer for yourself instead; very messy making yourself into one... Quote Link to comment Share on other sites More sharing options...
Kev walker Posted November 20, 2017 Author Share Posted November 20, 2017 Press works well It works as good as I hoped it would the round billet was 1 1/2 x 3” mild steel It also punched a couple of hammer eyes did a good job I have a vidio on instagram #bisopnorton1959 if you would like to see it thanks for your help D2ADBDF6-1566-4812-9A5F-64AC987A9738.MP4 Quote Link to comment Share on other sites More sharing options...
Joel OF Posted December 22, 2017 Share Posted December 22, 2017 Hi Kev walker press looks im-press-ive. If you don't mind me asking what was the job cost all in, and how many days to make? A hydraulic press is one of the many things on my wishlist. Did you put the video on YouTube too or just IG? I'm not on IG so can't find you/your vid on there. Quote Link to comment Share on other sites More sharing options...
Kev walker Posted December 26, 2017 Author Share Posted December 26, 2017 Hi Joel The whole fing cost me £1300 but it’s all new gear I could of done it cheaper with used gear but I sold some workshop tool that I didn’t use. you can make hammers easy and that’s what I built it for I will be posting some videos on YouTube of me making an Hammer with it in the new year (Bishop Norton 1959 )so if you subscribe when I post it You will see it straight away and maybe I should’ve done a bit of a video of it being built and my Tyre hammer cheers Kev Quote Link to comment Share on other sites More sharing options...
eseemann Posted December 26, 2017 Share Posted December 26, 2017 On 9/18/2017 at 3:12 PM, Frosty said: bomb The concussive force is lower on my worry list than the razor sharp steel darts that will follow break. Quote Link to comment Share on other sites More sharing options...
Joel OF Posted December 28, 2017 Share Posted December 28, 2017 Cheers Kev walker - that's about what I expected this sorta thing to cost, though I think the press you've made will have far more grunt than I need. Quote Link to comment Share on other sites More sharing options...
