Tzelik Hammar Posted September 12, 2017 Author Share Posted September 12, 2017 Huh. ok. well, that explains why I cant find it. Damp dirt in the desert is hard to come by I was trying to take a piece of flat stock and coil it so it kind of held itself inside the tuyere with spring tension. Probably overthinking things again. I only have access to a welder at work, so ill try to pull something together this afternoon. I probably could have just made a bar grate 5-6 times over while jacking with the silly spring idea... Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 12, 2017 Share Posted September 12, 2017 not to mention that the spring tension will go away when heated enough... I like using old adobe bricks as source for "forge dirt" Link to comment Share on other sites More sharing options...
Tzelik Hammar Posted September 12, 2017 Author Share Posted September 12, 2017 1 minute ago, ThomasPowers said: not to mention that the spring tension will go away when heated enough... Right. Valid point. Link to comment Share on other sites More sharing options...
Frosty Posted September 12, 2017 Share Posted September 12, 2017 Wet some sand and mix it with nice powdery desert dirt and let it sit in a sealed container for a while so the moisture evens out. NOT WET, you don't want even stiff mud, just damp enough to pack hard. If you had experience green sand casting I could tell you to "temper the soil to ram" and you'd know exactly what I meant. Don't sweat it, this isn't a perfection thing. A coil to fit INSIDE the tuyere? !! Try this, once you've rammed up the liner cut some oh 1/2" rd. or whatever's handy a couple inches longer than the tuyere is wide, make sure they overlap the clay, heck they could hang off the pan and be tong hangers if you wanted. Space them 3/8" - 1/2" apart and ram them into the clay. Perfectly serviceable bar grate. Hmmm? Frosty The Lucky. Link to comment Share on other sites More sharing options...
Tzelik Hammar Posted September 12, 2017 Author Share Posted September 12, 2017 I'll try some bar stock tomorrow. Wednesdays I take off to forge. I use a rivet forge though so the ends won't hang off for tongs ;p Link to comment Share on other sites More sharing options...
Tzelik Hammar Posted September 13, 2017 Author Share Posted September 13, 2017 Frosty, I think you have magical powers. Water fell from the sky last night and I found wet dirt everywhere! hahahahaha Link to comment Share on other sites More sharing options...
Frosty Posted September 14, 2017 Share Posted September 14, 2017 See? All that extra thinking for naught. Remember to keep your forge covered, wet all the time isn't good for them. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Tzelik Hammar Posted September 21, 2017 Author Share Posted September 21, 2017 First, this is not a historical blade, i just like the Seax shape. It's full Tang and the copper is wildly inaccurate. I like it though, turned out as intended (rough look included). The only change from the original was removing the large pin in the handle to keep the balance right. Still unable to upload pictures, hopefully I can do it tomorrow. Link to comment Share on other sites More sharing options...
MastaStan Posted September 21, 2017 Share Posted September 21, 2017 Good work. Not entirely my cup of tea. The handle looks a bit far forward on to the blade. Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted September 21, 2017 Share Posted September 21, 2017 Not bad at all for a first knife. I think the copper lookes really cool. That's one of those knives that makes me want to go hack at something! Link to comment Share on other sites More sharing options...
Tzelik Hammar Posted September 21, 2017 Author Share Posted September 21, 2017 The scales taper forward to cover the end of the copper, I nipped it too short. Shame the cedar grain doesn't show up in the pictures, it's actually really pretty. As for hacking... It's great Balance is about two fingers in front of the handle and it moves nicely for chopping on things. I'm debating giving it away or testing it to failure, as it's my first forged blade and I kinda want to see if I've made something reliable. Link to comment Share on other sites More sharing options...
Please sign in to comment
