GMoore Posted August 28, 2017 Share Posted August 28, 2017 I'm looking for a tool which will allow me to "stamp" in a parallel channel. I know I'm not explaining this very well, but I want to put veins on leaves, so the end result would be a small rounded line with a "groove" cut along both sides - but small. Any ideas? Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 28, 2017 Share Posted August 28, 2017 Got one; it's a very small top swage. The end is something like VV, use it with the screwpress and it leaves a ridge with troughs on either side. Link to comment Share on other sites More sharing options...
John McPherson Posted August 28, 2017 Share Posted August 28, 2017 Alas and alack! If only you knew a blacksmith! Then they could...make?...you the tool?...that you need?........ for blacksmithing...??? Or are you asking for a how-to on making your own tooling? There must be a hundred different tools that you could make out of scrap steel like springs or hex wrenches to texture leaves. Here is one. Link to comment Share on other sites More sharing options...
Al Stephens Posted August 28, 2017 Share Posted August 28, 2017 GMoore a simple punch can be made from anything, see picture Link to comment Share on other sites More sharing options...
Glenn Posted August 28, 2017 Share Posted August 28, 2017 How many leaves do you need to make? What size are the leaves? Link to comment Share on other sites More sharing options...
Al Stephens Posted August 29, 2017 Share Posted August 29, 2017 Here's a "leaf" punch I made about 20 years ago. Cut the veins with a chisel, ground it to shape on a belt sander. Made from an old 3/8" allen wrench. Leaf measures about 1/4" square. I've used it on brass, copper, aluminum, cold mild steel. Link to comment Share on other sites More sharing options...
Please sign in to comment
