aametalmaster Posted March 14, 2008 Share Posted March 14, 2008 This tractor part came in today with a giant cut out where the crack used to be. The part houses the steering box plus is the tank for the radiator and it froze. The guy ground it all the way thru and was going to braze it then he changed his mind. Neverless it was a large gouge. I gave it a few test tacks with some machinable cast rod and it looked like it was going to be ok so i proceded to connect the dots. Then i ground it all out and put some longer beads on it grinding between the beads as i went. I sprayed some pentrating suff on it and didn't see any cracks...Bob Link to comment Share on other sites More sharing options...
ironwolfforgeca Posted March 14, 2008 Share Posted March 14, 2008 Hay Bob what kind of cast rod did you use ? maker and No# ? please I do cast Iron welding every so offen to Steve's welding Link to comment Share on other sites More sharing options...
aametalmaster Posted March 14, 2008 Author Share Posted March 14, 2008 Crown Alloys 255 Nickel Alloy for cast iron. Complete instructions here...Bobhttp://www.crownalloys.com/page10.pdf Link to comment Share on other sites More sharing options...
Please sign in to comment
