Home built tire hammer nearly finished
First run testing of tire hammer I built. Largely based on Spencer and anvilfire pictures and any other photos or information I could find on the web. I wanted to take advantage of everything I could and using a hub assembly off the rear of a front wheel drive vehicle provided a brake system predesigned and fitted. 62 lbs ram weight, 800 lbs in anvil section, approx. 1200 lbs total as it sits (think I need to add a little more anvil weight as the ram came in above what I had planned), 1 hp motor at full rpm would be over 300 BPM but from the video it is obviously running slower than that. Still needing adjustments and tuning but I will wait until a proper guard is in place before using.
I am waiting for full testing and tuning before painting unit. Current investment just under $700 USD which includes a spool of mig wire and a new tank of shielding gas.
Video  https://youtu.be/ZmwaUShvo9M
