Hooking up dual tanks?
bmtt
Is there a way to hookup two tanks at once,and is it safe to do so? I have two 30# tanks and wanting to run both at the same time through one regulator then to the forge, as in have both open at the same time. Is this possible?
Good Morning, Welcome.
Please put your location in your avatar, there probably is someone close to you that you can ask questions of. For sure there is a Blacksmith Association you can mix with.
You can purchase all the fittings you need from your local hose/hydraulic fitting supplier. In your own town probably, not on-line. Buy what you need the first time.
Enjoy the journey, there is a beginning and there isn't a light at the end of the tunnel.
Neil
