Glenn
It followed me home
At one time I drove an '86 Honda CRX and many an item(s) followed me home in that mini work horse. One time 400 pounds of sucker rod taxed it but it made it home. Sadly a girl failed to yield while making a turn in front of me and totaled it.:angry: luckily I wasn't hurt.
Share this post
Link to post
Automotive adventures aside, the grinding discs were the real prize: at five bucks for  fifty-nine of them, that’s less than 10 cents each!
Share this post
Link to post
Just picked this hunk of bar up from the side of the road. About 1/2” x 2-1/2” x 28”.  Despite the location, it doesn’t look like leaf spring, so I’ll try a spark test when I get it home.
Share this post
Link to post
A couple of weeks ago I picked up 70+ lbs of random hardware. I also went to the NEB Spring Meet today and picked up some other stuff.
WARNING: PIC HEAVY
Share this post
Link to post
I found this in a tool box at that I bought at a garage sale today. Does anyone know what it is called or used for.
Also got an air compressor as well as some casters, hacksaws, and some random steel.
All for $30 btw.:D
Share this post
Link to post
Thanks a bunch. I will have to look for a victim... I mean patient to practice using the saw set pliers.
TP- I agree with you. The red thing is an opperator of pneumatic devices.
Share this post
Link to post
Didn’t buy the earlier shown vice & stand from CL for the mobile forge equipment but found this beauty next door (village). It’s a full functional 4 ½ in jaw vice and fully forged if you look at the lock plates, chiselled eyes for the screw box and rivets. The vice is only wire brushed and passivated with linseed oil. Greased the screw, dressed the push spring and made a new wedge for the join pin.
Was so glad to find this nice piece of equipment that I give the seller (20 dollares) one of my fire pokes to say thank you.
Build another vice stand in advance which is movable. Will finish (weld & paint) him today.
The big ‘b’ on the foot is a standard left over sample (2 ½ in plate) from edge hardness measuring to certify the gas-oxy cutting process from one of my clients. It’s add extra counter weight (55lbs) and balance to the stand. If the weight is not enough I will drive extra ground anchors though the holes in the ground or between the joints in the road stones.
Hope this little old guy will do his work very well:D.
Cheers, Hans
Share this post
Link to post
Went to my local scrap yard for a quick run yesterday.  I was early enough to beat the truck that hauls it all away every day so I had nice piles to pick through.  Found some nice coil springs, hay rake tines and something I've never seen before.  The pointy pieces slowly get wider as you go from the point upward.  I have no clue what they are so if anyone here knows, please let me know.  I plan on using the pointy pieces to make hardy tools.  What I do know about them is that they were long piece cut into several pieces and I think the very top piece was threaded and was quite large  at something like 2 or 3 inches.  I also had a 3/4 inch steel rod as well that is not pictured because it was so long.  $5 for all of it.
Share this post
Link to post
For the next picture,
I suggest that you put a known item beside the unknown one for comparison purposes.
Like a quarter, dollar bill, hammer, et cetera.
It then becomes much easier to visualize.
Just sayyin',
SLAG.
Share this post
Link to post
Ah, good point Slag.  The pieces in question are roughly an inch by inch square  near the point and increase to almost 1 1/2 inches toward the top cut-off part and the longest one is a little over 2 feet in length.  I hope that helps.  Yeah, how dumb of me they could be nails for all you guys know as the picture really gives no idea to size.
Share this post
Link to post
On my way home from church I noticed the local Fire Department loading a dumpster so stopped to inquire. They said it was all junk and to take whatever I wanted. I got the siren off the building roof, several old Scot air tanks, a lot of aluminum plate, about 50 pounds of brass fittings, and some turnout gear. Plugged the siren in and it works fine...  It was a good day for dumpster diving.
Share this post
Link to post
Your taxes bought that stuff so it seems fitting you can get some when they no longer need it. Good score on the siren.
Share this post
Link to post
Followed me home I feeeeeeeeel like it should be a foundry. Like it is asking me to fufill its destiny and upgrade it from a fryer broaster thing.
Share this post
Link to post
Hmm...commercial fryers rarely go much above 375°F/191°C, which might be a bit cool for foundry work.
Share this post
Link to post
Take a look at how much that cost new....they are not inexpensive. I would sell it off and get something more suitable. Well, I probably wouldn't as I am picking up used commercial kitchen equipment to use for their intended purposes.
Share this post
Link to post
Got some new belts, epoxy, and some axles from a silverado today. Thinking some hardy tools and punches out of the axles.
Share this post
Link to post
