Conor Saxton Posted July 21, 2017 Share Posted July 21, 2017 So i'm trying to make a mould of an old axe head i have (which i believe is viking inspired) to bronze cast as a gift. I use green sand to make my mould so my problem is that i can't get a mould to keep the gap in the axe-head. The only idea i have come up with is putting a steel rod made into the shape of the gap and putting it into the mould but i would prefer an alternative as this would take a lot of time and i don't think i have the proper tools. If anyone can come up with an alternative way i would appreciate it. Quote Link to comment Share on other sites More sharing options...
wpearson Posted July 21, 2017 Share Posted July 21, 2017 use a sand core. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted July 21, 2017 Share Posted July 21, 2017 Assuming you are casting this so that the axe eye is vertical you could make a post in the shape of the eye from whatever material you would use if you were doing lost wax casting. If you embed that in your sand that should retain your eye shape and you can just chip it out after the bronze cools - I think. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 21, 2017 Share Posted July 21, 2017 Perhaps a molasas bound baked sand core. A fairly basic casting process; where are you learning your sand casting from? Quote Link to comment Share on other sites More sharing options...
Conor Saxton Posted July 21, 2017 Author Share Posted July 21, 2017 Thanks for the suggestions ill give the sand core a try and hope it works. And ThomasPowers i learnt the basics from a friend and im trying to build on that from forums Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 23, 2018 Share Posted February 23, 2018 Hi, Conor, and welcome to IFI. If you haven't yet, please READ THIS FIRST. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted February 23, 2018 Share Posted February 23, 2018 You can use sodium silicate as a binder for making sand cores, but you need to either bake it or gas it with CO2 to get it to harden. Google "making sand cores". Quote Link to comment Share on other sites More sharing options...
