Scruffylookingnerfherder Posted July 20, 2017 Share Posted July 20, 2017 I am trying to put a handle on a knife and maybe a chisel that I made, and I am looking for an inexpensive way to do that. In general, would oak from the local Home Depot work for handle scales? Thanks for your time! Scruffy Quote Link to comment Share on other sites More sharing options...
Latticino Posted July 20, 2017 Share Posted July 20, 2017 Red and White Oak make good, functional knife handles, though they aren't all that aesthetic IMHO. I'm not sure how well they will hold up for a chisel, but that is all dependent on how the chisel tang or socket is designed and how you plan on using it. For a real budget source of oak for scales consider looking at old wooden pallets. The heavier ones are sometimes made of oak or similar hardwood. Quote Link to comment Share on other sites More sharing options...
lanternnate Posted July 20, 2017 Share Posted July 20, 2017 Another cheap source of wood "scales" is hardwood floor excess. If you can find an installer or a seller you can check if you can acquire their scrap pieces and shorts. That can get the classic oak, but also sometimes some of the more interesting stuff. Quote Link to comment Share on other sites More sharing options...
Scruffylookingnerfherder Posted July 24, 2017 Author Share Posted July 24, 2017 Thanks! Scruffy Quote Link to comment Share on other sites More sharing options...
Lou L Posted July 24, 2017 Share Posted July 24, 2017 I've heard it said a number of times that pallets are an excellent and free source of a number of hardwoods. Businesses of all types store piles of them they give away for free. I have yet to inspect a pallet for the quality of the wood, I usually end up burning them or using them to store stuff in the shed. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 26, 2017 Share Posted July 26, 2017 Find a place selling solid hardwood flooring and ask them for "samples". Places that sell things like wallboard, sheet metal, etc often have large strong pallets that they will give away---I used to have a sign company across the alleyway and I ended up getting a lot of 12' long 4x4's from their sheet metal and plastic sheet deliveries. (to remove the twisted nails I would first try with a crowbar and then if the tops popped off I'd heat the nail with a propane torch and then pull out with a large set of vise grips and a block of wood.) Quote Link to comment Share on other sites More sharing options...
