JHCC Posted July 13, 2017 Share Posted July 13, 2017 Straightening heavy coil spring can be a pain, especially if you don't have a forge big enough to heat the whole thing all at once and a tractor or forklift to pull it straight. I've tried working in sections on the anvil, with a bending fork, or using the hardy hole itself as a bending fork. All of these work, but they're awkward. I was thinking about this the other day, when it occurred to me that uncoiling into some kind of jig could be an interesting possibility. And here it is: This is simply a piece of angle iron clamped in the post vice with a vice-grip at one end. Clamp the end of the section you want to straighten, and uncoil the spring into the angle, using a scrolling wrench for extra leverage. Given the size of my fire, I was able to uncoil about 4" at a time. Alternating between two workpieces, this went really fast and very well. And here are two 18" sections of 5/8", fresh from the jig. Obviously not perfect, but they'll be getting straightened further later on. By the way, these are intended for a pair of Brazeal-style hammer tongs. Note the taper that's already in them; I realized I could take advantage of that to minimize the amount of drawing-out I'll need to do on the reins. Quote Link to comment Share on other sites More sharing options...
Jasent Posted July 13, 2017 Share Posted July 13, 2017 Tagging for later. Thanks for sharing Quote Link to comment Share on other sites More sharing options...
Millhand Posted July 13, 2017 Share Posted July 13, 2017 Exelent idea! Thanks for the post! Quote Link to comment Share on other sites More sharing options...
Will W. Posted July 13, 2017 Share Posted July 13, 2017 Simple, yet pragmatic. Good idea. Quote Link to comment Share on other sites More sharing options...
Leon Renaud Posted July 14, 2017 Share Posted July 14, 2017 following. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 14, 2017 Share Posted July 14, 2017 Nice, simple fixture; I'd improve it by making it so you didn't need the vicegrips. One way would be to cut the angle of the angle iron an inch and a half or so and fold the bottom tab up and drill the appropriate sized hole in it so slip the hot steel end into the hole and start unwinding it. Remember that hot steel expands and so will need a slightly bigger hole than the nominal diameter of the cold spring. Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 14, 2017 Author Share Posted July 14, 2017 That's certainly an interesting possibility. I've been thinking about a few options, but one advantage of the vise grips is how solidly they hold the workpiece. Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 23, 2017 Author Share Posted July 23, 2017 Version Two: made a cut in the corner of the angle, about 3/4" from each end and bent the resulting sections backward. This creates a built-in holder for the end of the coil. There's one at each end, to accommodate two different sizes of coil spring. And it works pretty well! The smaller coil can be moved with a bending wrench, but the heavier stuff does better if you slip a piece of pipe over the other end as a lever. Quote Link to comment Share on other sites More sharing options...
Will W. Posted July 23, 2017 Share Posted July 23, 2017 I like version 2.0 even better. If I worked with coil spring often enough, I would definitely make one. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 24, 2017 Share Posted July 24, 2017 I like the no drill version of my suggestion! Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 24, 2017 Author Share Posted July 24, 2017 Me too. (Especially since I don't have a drill that size.) Quote Link to comment Share on other sites More sharing options...
JHCC Posted January 18, 2019 Author Share Posted January 18, 2019 Addendum: I have since welded a tab of 1/4" plate to the back of this tool, which can be gripped much more securely in the vise. Quote Link to comment Share on other sites More sharing options...
Casapa Posted January 18, 2019 Share Posted January 18, 2019 Nice tool, will remember this.:) This guy makes it look easy. Quote Link to comment Share on other sites More sharing options...
SFC Snuffy Posted January 19, 2019 Share Posted January 19, 2019 Well... he certainly straightened the spring quickly. But with no gloves, no apron, short sleeves, and only a couple of vice-grips holding his stock, he's one small slip away from a serious injury. In the (US) Army, we say "If it's stupid but it works, it isn't stupid." That's well and good right up until it doesn't work (or doing so gets you hurt). JHCC, I've been thinking about straightening some springs. When the time comes, I'll certainly give your jig a go. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted January 19, 2019 Share Posted January 19, 2019 I like the jig setup.. Nicely done JHCC.. Very nice indeedie.. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 19, 2019 Share Posted January 19, 2019 I first ran across the method shown in the video in Weygers' blacksmithing books back in the '70's as I recall. For smaller springs---like garage door springs it's possible to grab the end and run out the shop and down the alleyway getting 20-30' of straightened spring with practice---and with everything arranged so you can grab and run. The propane forge helps a lot to get a goodly length of spring up to temp to start. Now I have a spring made from 1.5" stock that will probably take a press even hot...(from a dirt mover) Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 19, 2019 Share Posted January 19, 2019 We welded a piece of pipe over some 2" sq to fit the hitch receiver in a pickup truck and welded a ring to the end of a coil. We had a short chain on the pull truck and the anchor truck parked at 90*. When the spring came out of the fire two guys ran it to the anchor truck, hooked the chain to the ring and the guy driving the pull truck pulled up the driveway. Took maybe 30 seconds from forge to laying on the ground. I salvaged a coil spring from a lot near by, it weighs in excess of 360 lbs. the wire is 2.375" dia, the coil is 12.75" in dia, c-c of wire. I think a big fire ad a couple dozers would work a treat but . . . A couple minutes with the torch and I have plenty to make a few hammers. Less than 1/2 turn on the coil that is. I don't know what I'm going to do with all that spring and there's another just like it on that lot. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted February 4, 2020 Share Posted February 4, 2020 On 1/19/2019 at 1:24 PM, Frosty said: there's another just like it on that lot. Sounds like a good excuse to take a ride up to your place...... Only a two day and 14 hour drive from here...... JHCC, thanks for linking to this thread. Robert Taylor Quote Link to comment Share on other sites More sharing options...
arkie Posted February 4, 2020 Share Posted February 4, 2020 For most applications using coil springs (car, truck, etc.) such as punches, small drifts, and so forth, which are seldom longer than 10" I find it MUCH easier to just measure along the coil segment for the length needed and cut it off with an angle grinder. Any thing longer such as a hold down, do it the same. It's then easy to just heat the smaller lengths of the cut off coil in the forge and straighten, than using the heat and pull method. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 5, 2020 Author Share Posted February 5, 2020 The photo that showed the tab on the underside seems to have gone bye-bye, so here’s what it looks like now: The little bits of rebar (rather messily welded, to be honest) hook onto the underside of the vise jaws and keep the jig from rotating: 19 hours ago, arkie said: For most applications using coil springs [...] I find it MUCH easier to just measure along the coil segment for the length needed and cut it off with an angle grinder. I generally agree, but this works great if you need, for example, 4-5 feet for a spring fuller. This section of 7/16" was straightened in a single heat: And became this: Quote Link to comment Share on other sites More sharing options...
