Melw45
NWGS
18 posts in this topic
Posted (edited)
I started a no weld grinder.
Last weekend  I hit the steel supplier.
I picked up the tube a flat stock needed.
Over the last few days i have been picking up the hardware I need as well.
First thing i had to do was cut the bad torch slag off of one end. So out came the old Harbor Freight 4x6 bandsaw.20170628_101956.thumb.jpg.cd3540b3c9b4aeca266cab8af7aa0139.jpg
Then i had to true up the cut end so the holes will be in tbe correct place.
Some grinding witn a angle grinder and filling I was ready to cut it to length.
Back to the saw and cut to length.20170628_123025.thumb.jpg.496f1d061ccf63e7de68e3514d457cbe.jpg
I got the side holes layed out and drilled to size.
Then the mailman showed up with the bearings.
Yes I made notes so I put the holes on the right end.;)
Thats all for now will post some more when I make some progress.
Thanks for looking!
Mel
Edited by Melw45
spelling
Share this post
Link to post
I remember when I made mine.:) I use it almost everyday now, still need to make more attachments.
Share this post
Link to post
Once you're done with the build, you'll wonder how you ever got along without it. Like Dylan, I use mine about every day.
Share this post
Link to post
Thannks for the replys. i did not get to work on it today. My wife had other things for me to do.:D
Mel
Share this post
Link to post
My wheels came in the mail today. They are the glass filled nylon ones.
Here is a photo I swiped from the eBay add. Nice looking.
Mel
Share this post
Link to post
Those are the same wheels I have on mine! There the ones from oregon blade maker right?
Share this post
Link to post
Doesn't your cut off saw cut straight? Usually it means the blade is dulled on one side or incorrectly tensioned.  Just take a wire brush and clean rag to the steel before you cut it, just a little grit will blunt the teeth and turn a blade into a wonky cutter. It's an easy precaution when cutting old steel and pays for itself in blade costs. I use a Jet 7" x 13" HV band saw all the time and blades run about $20 ea with shipping to AK. I have a cup brush on a peanut grinder that hangs out next to it. They're part of a set. I brush steel before I chuck it up, it's way less work than grinding things square and to dimension afterwards. My blades last WAY longer too.
Share this post
Link to post
I have adjusted it. The movable jaw on the vice had crept over and was touching the guide. Now it just takes a few strokes with the file to close up the gap.
The other thing was the stock not down flat in the vice. I have found that a bar clamp on the outside of the blade keeps that from happing.
I guess ineed more hands.
Thanks for the advice. I have some dirty tube to cut next.
Mel
Yep.
Thanks for looking.
Mel
Share this post
Link to post
I have made some progress yesterday.
Both uprights and the tool bar holder.
Here are some photos.
Mel
Share this post
Link to post
Yesterday I made the tension arm and the tracking wheel parts. Today drilled the mounting brackets for the tracking assembly. I also cut the clamps.
Still need the 3/8" holes in them. Here is a photo.
Mel
Share this post
Link to post
Mel
Yep.
Thanks for looking.
Mel
Wouldn't you know it, I had a simple piece not line up properly and took a square to it to see why. Turns out the vise jaw on my cut off had moved or been bumped out of square by a couple degrees. Thinking back I'm pretty sure I bumped it loading a piece of heavy stock a while back. I have a couple roll helpers and they make it easy to bump the saw.
A protractor square should be on or right next to a cut off saw. Checking only takes a couple seconds, pay back comes with the first piece you don't have to grind square. Here's a kicker, I had to hunt for my square and a light so I could see the gap in the vise's heal jaw. <sigh>
Share this post
Link to post
Frosty
Glad you found the problem.
I finshed drilling the 1x 1/8 bars for the clamps. No photos today.
I also started the tool arm.
Then had to run some errands so i will drill more tomarrow.
Mel
Share this post
Link to post
It's a little embarrassing it was out of square, I usually check it pretty often. At least it didn't bite me in the butt, it must've been a good Karma day.
Share this post
Link to post
A pic of the latest parts. Allmost time to put it togather.
Still need to cut the keyway in the drive shaft and deside about the step pullys.
Mel
Share this post
Link to post
No photos today. Just cut the tubing for the tool rest. Still need to drill some holes and tap some threads.
Mel
Share this post
Link to post
Made a bunch of progress over the last couple of days.
Made the parts for the table and cut some ugly keyways in the drive shaft.
I now have a large pile of parts.20170720_185236.thumb.jpg.6ea583188a65624a1a8d98c4cc71d4d1.jpg
Next I did a test assembly.
20170720_195244.thumb.jpg.7ea9a39fa8a0f43e19abfdd4822a9ef3.jpg20170720_195252.thumb.jpg.e538b315e2537617ac53330af6349a84.jpg
Staaarting to look like a grinder.
Thanks for looking.
Mel
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
