brianstucker Posted June 22, 2017 Share Posted June 22, 2017 I still need to do some more work on it. Im gonna line the floor with some refractory and coat the inside with some Metrikote. I also got to re do the idle circut. I just wanted to test fire it. Link to comment Share on other sites More sharing options...
James Bond Posted June 22, 2017 Share Posted June 22, 2017 Regards Your project is great What material did you use to concentrate the heat in the box, and make it not warm the outside of the box Link to comment Share on other sites More sharing options...
Kaleb Posted June 22, 2017 Share Posted June 22, 2017 3 minutes ago, James Bond said: What material did you use to concentrate the heat in the box I guessing some sort of kaowool and then, 1 hour ago, crappiew said: refractory and coat the inside with some Metrikote Link to comment Share on other sites More sharing options...
James Bond Posted June 22, 2017 Share Posted June 22, 2017 8 minutes ago, Kaleb said: I guessing some sort of kaowool and then, oh, ok thanks Sr Link to comment Share on other sites More sharing options...
brianstucker Posted June 22, 2017 Author Share Posted June 22, 2017 I used 1 1" layer of Kawool and a 2" hard ceramic fiber board. 3" of insulation on the walls. Link to comment Share on other sites More sharing options...
Please sign in to comment
