templehound Posted June 21, 2017 Share Posted June 21, 2017 When I was a little boy puukkos were my favourite, most important knives. My first self cut deep flesh wounds came from Puukko blades. They were always sharp. I loved them. .....This small puukko has a blade with rhombic cross section and is made of 1.2552(80WCrV8) tool steel. There is copper for the fittings and a stacked leather handle.with the tang riveted on the butt. overall length measures180 mm. Cheers Quote Link to comment Share on other sites More sharing options...
Daswulf Posted June 21, 2017 Share Posted June 21, 2017 Excellent work Templehound. If you don't mind my asking, what finish do you use on the leather? Quote Link to comment Share on other sites More sharing options...
gmbobnick Posted June 21, 2017 Share Posted June 21, 2017 The Puukko is legendary and it appears you have honored it well. What a superb tool. It will teach a person to make small, sure cuts and no rash moves, as it sounds like you learned...and as it shows in your work as well. Great job! Quote Link to comment Share on other sites More sharing options...
templehound Posted June 22, 2017 Author Share Posted June 22, 2017 19 hours ago, Daswulf said: Excellent work Templehound. If you don't mind my asking, what finish do you use on the leather? Thanks DASwulf! Actually there is no finish on the handle in the common sense. I ground to grit 240 with no handsanding on the leather, just on the fittings I handsanded with grit 320 a little bit, getting the tiny facettes out. I had the result that, the finer I handsanded the leather, the less homogeneous it looked. then impregnated it with several coatings of hot bees wax. I squeezed and massaged the handle until the knife cooled down, wiped off the wax from the fittings, and it looked good. Ground color of the leather was dark gray. 17 hours ago, gmbobnick said: The Puukko is legendary and it appears you have honored it well. What a superb tool. It will teach a person to make small, sure cuts and no rash moves, as it sounds like you learned...and as it shows in your work as well. Great job! Thank You very much gmbobnick! Quote Link to comment Share on other sites More sharing options...
Daswulf Posted June 22, 2017 Share Posted June 22, 2017 Thank you for the info Templehound. I would like to try doing a stacked leather handle some time. Quote Link to comment Share on other sites More sharing options...
