Sign in to follow this
Followers 0
BlueClawWorkshop
Copper Food Safe Coating
5 posts in this topic
Hi All,
I am making a copper chalice and ciborium for a Catholic Mass to be celebrated during a mission trip.  I am concerned about the possibility of copper tainting the wine.
1.  Is my safety concern valid?  Do I need to use a protective coating?
2.  What food safe coatings can I use and where can I get them?  (My searches so far have not been fruitful.)
3.  I am not comfortable with my skills to purchase silver and gold, so the next possibility is pewter.  If you recommend I use food grade pewter, is there a special way I need to forge pewter?
Thank you,
Anthony
Share this post
Link to post
Well I would have suggested taking sheet silver and hard soldering a silver liner in the cup.  Wine can be quite acidic especially as it turns toward vinegar---not a good mix wrt food safety. Now the ciborium will probably be ok if it's polished before use.
Share this post
Link to post
Would tinning the inside (as one does with copper cookware) be an option?
Share this post
Link to post
Some ciboria have internal glass cups within the enveloping metal vessel.
Could you locate such a glass vessel that would fit snugly within your crafted ciborium?
There are a number of acids in wine such as tannic acid. T. P. is right that ethyl alcohol will turn to acetic acid if left standing.
SLAG.
Share this post
Link to post
I was thinking tin, or what about enameling? Both can be done at home.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Followers 0
