Cyrilak Posted June 2, 2017 Share Posted June 2, 2017 Hello all, I am going to start building my forge and I am just finishing ordering everything, I have a few questions about insulation. From what I have read, it seems like using ceramic wool is the easiest way to insulate a gas forge, I know it needs to be replaced once in a while because it wears down. Is it best to have 2" of insulation? And are you supposed to line the wool with refractory cement? Or just use straight wool? I know the stuff is bad for your lungs and I was wondering if it lets particles off in the air while it's burning. I plan on laying fire bricks on the very bottom of my forge. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted June 2, 2017 Share Posted June 2, 2017 No bricks; nix the bricks!!! Ceramic wool is not your easiest choice; its the most practical choice. Use two inches, but lay it down in two 1" layers, for best results. Mix up fumed silica or buy silica rigidizer to treat each layer with with; and heat each layer SEPARATELY. Then you are ready to think of your hot face finish coat. Refractory is fine, and other coatings are also fine; you can do a little digging to unearth what they might be. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 2, 2017 Share Posted June 2, 2017 "From what you have read"? I believe building a double lined forge has been gone over to death right here. Read a LITTLE more, 1% of what's posted would answer all your forge build questions many times over. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted June 3, 2017 Share Posted June 3, 2017 Check out the Build a Gas Forge attachment on the Forge Supplies page at www.WayneCoeArtistBlacksmith.com for instructions on how I like to build a good, long lasting, efficient forge. Let me know how I can help you Wayne Quote Link to comment Share on other sites More sharing options...
Cyrilak Posted June 3, 2017 Author Share Posted June 3, 2017 Thank you those of you that actually helped 4 hours ago, Mikey98118 said: No bricks; nix the bricks!!! Ceramic wool is not your easiest choice; its the most practical choice. Use two inches, but lay it down in two 1" layers, for best results. Mix up fumed silica or buy silica rigidizer to treat each layer with with; and heat each layer SEPARATELY. Then you are ready to think of your hot face finish coat. Refractory is fine, and other coatings are also fine; you can do a little digging to unearth what they might be. Why not put bricks on the bottom? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted June 3, 2017 Share Posted June 3, 2017 Mostly, you will find a coice between hard firebrick, which has nearly zero insulation value, and insulting firebricks which cannot stand up from the rapid thermal cycling forges go through; they rapidly crack and crumble away. Of course, there are in between bricks that are somewhat tough and somewhat insulating, if you are willing to do the research... Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted June 3, 2017 Share Posted June 3, 2017 Hard bricks are a heat sink.. A cast floor of Kast-0-Lite will be resistant to flux and will provide some insolating benefit. Let me know how I can help you Wayne Quote Link to comment Share on other sites More sharing options...
Cyrilak Posted June 3, 2017 Author Share Posted June 3, 2017 Thanks for the advice guys, I'll do the 2 one inch layers with the rigidizer then the refractory on the final later Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 3, 2017 Share Posted June 3, 2017 Good, you'll be much happier with the results. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
