Cole Eisenbath Posted May 29, 2017 Share Posted May 29, 2017 I just received the Majestic Forge 2 burner knife forge. I was under the impression that it could get to forge wielding temperature, but I have not been able to even get the metal up to yellow. Is there any way I could mod this forge be able to weld with it? If anyone has some advice or a solution that would be greatly appreciated. -Cole Eisenbath Quote Link to comment Share on other sites More sharing options...
alangerhans Posted May 29, 2017 Share Posted May 29, 2017 What pressure are you running it at? I have the three burner forge and was having similar issues. I lost the instruction sheet that came with it (if anyone can send me a copy I'd appreciate it) so I'm not sure, but I don't think it was very clear about what pressure you need it to be to forge weld. I haven't tried yet because of the fuel consumption but I think I wasn't running it nearly high enough. I run mine around 10-15 psi and i don't think it would weld at that temperature. Quote Link to comment Share on other sites More sharing options...
Birksy Posted May 29, 2017 Share Posted May 29, 2017 I have the same problem. I have used it twice (the second time earlier today) and put it about 12 psi and couldn't get it to yellow Quote Link to comment Share on other sites More sharing options...
Cole Eisenbath Posted May 30, 2017 Author Share Posted May 30, 2017 I have only been running mine at about 5 to 8 psi 10 at the most I will have to try it at a higher pressure. I will post the results. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted May 30, 2017 Share Posted May 30, 2017 Going forward from where you are, a heat reflection coating will do you the most good for the least effort and money. Several of the guys on this group brew up their own, so... Quote Link to comment Share on other sites More sharing options...
Cole Eisenbath Posted May 30, 2017 Author Share Posted May 30, 2017 I'll be sure to try that. Can you buy this stuff at like a lowes or Home Depot? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 30, 2017 Share Posted May 30, 2017 What did the manufacturer suggest when you contacted them? Quote Link to comment Share on other sites More sharing options...
Hammerfall Posted May 30, 2017 Share Posted May 30, 2017 My $215 Ebay forge I lined with mizzou gets to welding temps easily. Quote Link to comment Share on other sites More sharing options...
Cole Eisenbath Posted May 30, 2017 Author Share Posted May 30, 2017 Will any high heat cement work? Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted May 31, 2017 Share Posted May 31, 2017 You need an Infrared Reflective product. You will probably not find it at a big box store. Let me know how I can help you Wayne Quote Link to comment Share on other sites More sharing options...
Cole Eisenbath Posted May 31, 2017 Author Share Posted May 31, 2017 I'm having trouble finding the product. I would greatly appreciate it if you could send me a link. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 31, 2017 Share Posted May 31, 2017 You mean besides the one Wayne posted for you already? www.WayneCoeArtistBlacksmith.com Quote Link to comment Share on other sites More sharing options...
jcornell Posted May 31, 2017 Share Posted May 31, 2017 The commercial products are Metricote, Plistix and ITC-100. Many of us brew up a combination of kaolin and zircopax for pretty much the same result at lower cost. You won't find any of these at Lowes or Home Depot - try Axner or Wayne Coe or High Temp Tools to name three off the top of my head. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted June 1, 2017 Share Posted June 1, 2017 Or...I can recomend a really spiffy mixture for a whole lot more money Quote Link to comment Share on other sites More sharing options...
Cole Eisenbath Posted June 1, 2017 Author Share Posted June 1, 2017 I ran my forge at 15 psi. It was nearly to forge welding temperature, hopefully with a coat of Plastix I will be able to weld. Quote Link to comment Share on other sites More sharing options...
