cedarghost Posted May 17, 2017 Share Posted May 17, 2017 How would you do something like this on a full tang knife? Epoxy the material together before attaching to the knife? Thanks, Quote Link to comment Share on other sites More sharing options...
Latticino Posted May 17, 2017 Share Posted May 17, 2017 That is how I have done it in the past. I suppose you could try to assemble it on the knife while putting on the scales, but I think that would be a bear to align, not to mention drilling the rivet holes. Quote Link to comment Share on other sites More sharing options...
cedarghost Posted May 17, 2017 Author Share Posted May 17, 2017 Thanks for confirming. Quote Link to comment Share on other sites More sharing options...
lanternnate Posted May 27, 2017 Share Posted May 27, 2017 Also consider assembling the handle as one block like it would be a hidden tang then rip lengthwise down the middle on a bandsaw to turn it into two scales. I've done this once with just different woods (project was ultimately a fail because one of the woods used was just too soft and didn't finish well). Doing it as one block then ripping it makes sure the two sides end up perfectly matching. Quote Link to comment Share on other sites More sharing options...
cedarghost Posted May 28, 2017 Author Share Posted May 28, 2017 15 hours ago, lanternnate said: Also consider assembling the handle as one block like it would be a hidden tang then rip lengthwise down the middle on a bandsaw to turn it into two scales. I've done this once with just different woods (project was ultimately a fail because one of the woods used was just too soft and didn't finish well). Doing it as one block then ripping it makes sure the two sides end up perfectly matching. Makes sense! Quote Link to comment Share on other sites More sharing options...
