thyNemesis Posted March 8, 2017 Share Posted March 8, 2017 Hello, I'm about to start to dress my forklift tine anvil. I was wondering if anyone has any suggestion on where I should grind in my different radii. I am looking to make some knives, some tongs and whatever other things I might want to make. I seen a square post anvil where he had a radii on each side with the following radii, 1/2, 1/4, 1/8 and just broke the edge on one side of his square post anvil, however, mine is rectangle shaped. I don't know where to stand in relationship to the anvil to use my anvil in the most effective way. If this was your anvil, what sides would you put the above radii for best use of the surface? Looking at my anvil, what side would you put the 1/2 radii, the 1/4 radii?, etc... Thanks. Quote Link to comment Share on other sites More sharing options...
NickOHH Posted March 8, 2017 Share Posted March 8, 2017 The short edges could have a different radius on each of them the longer side could have say 1/8 on one end and transition into 1/4 or so inch radius on the other end ,matched on the opposite side Quote Link to comment Share on other sites More sharing options...
thyNemesis Posted March 8, 2017 Author Share Posted March 8, 2017 Thanks, So if you were standing in front of my anvil, where each small sides where on your left and right, would you put the 1/2 radii on the right side? I like your idea on making the long sides transition from 1/8-1/4, are you saying I should mirror them on the closer side as well? 1/8----1/4 1/8----1/4 Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 8, 2017 Share Posted March 8, 2017 Personally I don't see the need to repeat a radius. I'd do one long side 1/8 to 1/4 and the other 1/4-1/2 and reserve the shorter sides for later when you have a need for one not present. Quote Link to comment Share on other sites More sharing options...
