Mitch W. Posted February 24, 2017 Share Posted February 24, 2017 Purpose of New Thread: Documenting my failures and successess while attempting to build my first propane forge. Very detailed for anyone who is super new like me. There is no reason to read or follow this thread any further if you are an expert at building forges and blacksmithing. This thread should be beneficial for those who have very minimal skill and knowledge related to blacksmithing, like me, but are now falling in love with the craft. When I say minimal, I mean limited tools, limited knowledge of how to use certain tools, and your wife will not allow you to even unclog the toilet BC she fears what may follow! If that describes you, then you and I can relate with one another. After spending several days reading through multiple threads on this site, I learned a few things. First, there are a TON of EGOs in the blacksmithing community. Do not let the keyboard warriors scare you from the valubale resources this site has to offer. Two, do not expect someone to be nice to you because you just now learned about blacksmithing and want to build katana swords BC you binge watched 3 seasons of Forged in Fire. Three, don't ask questions unless you have researched the problem thoroughly and are still lost. You will get an answer, but it probably won't be what you were expecting. (If someone retorts what I write about that, then go read a few threads because you obviously haven't read any.) Four, spend time putting your bio together so people know where you are from. I've already had some local reach out to me and I'm looking forward to working together with him some day. Again, I'm still learning all the "unwritten rules" as I go along, but I learned most of them by reading through several threads. I would recommend you do the same. Soooooo, let me begin by saying I love watching Forged in Fire. I've read a few posts in here and we may be in the minority by admitting we like the show. Because of some of the comments I've read, I have embraced the idea of being called a "Forged in Fire" TV smith. If we survive not blowing everyone up, we may one day pound some metal into an object! However, my son and I love the show and are eager to learn more. So that's how I ended up here. Along with this site, I watch a ton of YouTube videos for building forges and blacksmithing. Some are better than others, but I learned more by reading the Forge 101 posts here. Which brings me to the forge build... Before I learned about this site I started building a forge out of a propane tank. (See pic) Be super careful cutting these bad boys up. Again, we are not expected to survive long, so don't give us TV Smith's a bad name. Just make sure to bleed the propane out of the bottle, clean it, and "air it out" for a few days before hacking away. I cut away both ends of the tank and was left with 12 inches in total length . I used a handsaw BC I didn't want to risk the sparks and propane having a party together in my garage. I then researched forge liners on google and found kawool was an option. I bought some on amazon and thought this was super easy. I then quickly found out you need to wear a good mask while working with this stuff. No, the little white mask that old people wear will not work. Drop the coin on a nice mask because you will use it A LOT! Do not go cheap on this. Sell a kidney if you must, but save your lungs with a proper mask. Your kids will need one at all times too. The liner was actually really easy to put on. As you can see in the picture, I thought I had it all figured out....... then I stumbled onto this website and quickly realized I'm really unprepared to make a forge, let alone an efficient forge for my needs. So hopefully you learn from my mistakes and read through all of this before you start a build. Now I'm going to finish the build I started because I want to see this through. After reading a few posts, I learned that you need to do some math and learn how to measure in cubic inches. If you are like me, I have no clue what that is, but I dare not ask here, so I went back and asked my friend Google. I like Google because it doesn't judge my stupidly. Long story short, it's how big the inside of my forge is. The reason this is important is because there is a guy who goes by the name Frosty, who posts all kinds of information on this site. He even has a burner that he created and gives very detailed plans of it under the forge tab. (Forge > Frosty "T" Burner) He basically tells you how big the forge needs to be, in order for his burner to efficiently heat the forge. In my case, I need to make the measurements and find out because I don't know. Being stupid, I just rushed into building the burner because I assume it's a one size fits all kinda deal. Now I know the forge needs to be somewhere in the ranges of 300 - 350 cubic inches. If I'm saying that wrong, don't worry, I will be corrected within hours. Point being, check out the post related to the Frosty T Burner Quote Link to comment Share on other sites More sharing options...
Mitch W. Posted February 24, 2017 Author Share Posted February 24, 2017 So don't go off and create the best forge in the world because it will turn out like a pile a garbage, which will look a lot like my forge (see pic). I've since redesigned a new forge that I will build and I had to do math and a ton of research. But that post is for another day. I need to finish this forge first, because I'll learn more from failing on this one than just giving up on it. You will also notice that I have fire brick ( I think) in the forge. Well that's there BC I thought I was smart, but it turns out that's a stupid idea. So don't do that either. I literally went to a store that sales brick for outdoor pizza ovens and asked for 4 test pieces. They gave it to me for free and I thought it was a super genious idea. Instead, I ended up with bricks that I don't even know what temp that are rated for. Yes, certain bricks have different ratings for heat. Some are soft and some are hard. You guessed it, I read about it in a post on the forum. Which is where I also learned about kiln. I'm forewarning you, do not open Pandora's box and tell a smith on this forum what is the best product to line your forge with. After reading through a ton of posts, there is a guy who sales this stuff and I'll be sending him my business. Just google Wayne Coe Blacksmith and you will see the link to his website. There are several posts that get into kiln and things to use to line your forge and his website has come up several times. If you want to get into the science behind the products, then go read it yourself. I read those posts several times and I'm still not sure I understand it. So, my thought is I will contact Wayne and line my forge with some of the products he sales. It's said to be similar to ITC-100, but better. I like better. BTW, I bought ITC-100 because I watched a YouTube video swearing by the stuff and I was going to lather the forge like a German Choclate cake. Again, I was wrong!! My thought was to line the entire forge with ITC-100, to include the bricks, but that would be a big waste of time. I haven't even set where I want my burner to be located and I'm thinking about giving my forge a bath in ITC-100. So again, draw out your plan first. Literally, draw out what you want it to look like and do the math. You even need to consider the path for the flame. You can't just throw stuff in the forge like I did and expect it to heat metal for your katana build. So at this point, I decided to go back to the T burner and make it work first. My mindset is to get a working burner that I can test inside of the forge and then start tuning it. I may be wrong, but I'm going to place my burner at a slight angle instead of pointing straight down into the forge. Several posts talk about hot spots that are created in the forge because the flame is focused in a certain area and not dispersed along the entire forge. Now I haven't found a formula, yet, for proper placement of the burner, but again this is a learning process. Not every forge is the same, so I wouldn't expect an exact placement formula. Another thing I learned is the purpose of the forge. You don't need a giant forge if you plan on doing jewelry or small parts. There are multiple burners and forges for different needs. So read around and find what forge size is best to start with. As for me, I want to learn to make Tomahawks. With the method I want to use (flux) I have to do research on the liner. I learned that Flux eats away at certain liners and bricks. But I'm betting Wayne Coes products will fit my needs, if followed properly. Again, I probably saved myself a lot of heartache by doing some research before lathering my forge in ITC-100. Now look at that, a TV inspired smith learning something. Maybe there is hope for us newbies after all! If you don't plan to introduce flux to your forge, then maybe your liner will be different. You won't know until you decide the purpose of the forge. If you read enough posts, all the grey beards will tell you there is no such thing as a forge that does it all. There is wisdom in those grey hairs, so absorb it before they realize they could get paid for that knowledge. Now my burner build didn't go so well. I've never tapped, welded, or worked with a drill press. But that all changed last week when I gathered a few tools and failed miserably in the process. So you can see that I created a very bad version of the Frosty T Burner. Even though Frosty goes into pain stacking detail on how to line up the holes to tap them straight and center, I still found a way to screw it up. The good news is I got my Tap and Die set on sale at Harbor Freight. I didnt even know what a tap and die set was, but now I do. I actually bought spare black pipe to practice my drilling and tapping. Once I was comfortable, I moved on to the real thing. So by looking at the pics, you can see how offset the holes are that I tapped. BUT, I bought spare parts and I get to try again this weekend. I also get to figure out what the difference is between a ball valve and a needle valve. And what type of regulator to use to control the PSI for my burner. I don't know squat about any off these items, which is going to be pretty important if I want to build a forge. I'll probably head over to a RV place because there is one close by. I've read several posts that warn newbies like me to be careful with propane. The point here is, don't let anyone scare you because you don't have the knowledge base they do about propane. Get motivated and go out there and educate yourself. Educate yourself on the safety issues and use common sense. I'll update my post this weekend on my progress and hopefully by the time you read this, I'll have already made all the mistakes you can avoid. I'm the meantime, enjoy looking at my terrible T burner build. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 24, 2017 Share Posted February 24, 2017 Mitch: I've read your thread so far. Are you telling experienced folk to shut up and leave you to muckle it out yourself? Encouraging other beginners to ignore experienced advice is NOT a service. Don't worry, I won't bother you again unless you ask me a directly, I won't even tell you what's wrong with the burner shown. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted February 24, 2017 Share Posted February 24, 2017 Frosty, you must have read something differently than I did. What I took away from his posts was specifically to listen to the "grey beards," but do your own research. We have a guy here with zero experience with forging or even the use of tools some of us would consider basic, yet he has searched, studied, made mistakes, practiced, and learned from those mistakes. He admits to getting ahead of himself and making a few bad choices in his enthusiasm to get started, but he has slowed down and done some more reading to see where he went wrong. As I see it, the purpose of this thread is to encourage newbies with no experience to take the time to do their homework and listen to the Frosty and Mikey folks out there to end up in a better place. I never got the impression he was encouraging beginners to ignore experienced advice at all. Mitch, assuming I got the tone of your post correct, keep at it. You're making good progress, but as you've already discovered it does pay to do the research and planning before diving in head first. One other minor point. The tap and die sets you can get at HF are absolute junk in my experience. Unless you think you need an entire set you'd be better off buying quality individual taps you need from a reputable source. Believe me, you'll notice the difference when you use them. A good tap makes it much easier to start the threads and keep them centered. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 24, 2017 Share Posted February 24, 2017 3 minutes ago, Buzzkill said: Frosty, you must have read something differently than I did. What I took away from his posts was specifically to listen to the "grey beards," but do your own research. We have a guy here with zero experience with forging or even the use of tools some of us would consider basic, yet he has searched, studied, made mistakes, practiced, and learned from those mistakes. He admits to getting ahead of himself and making a few bad choices in his enthusiasm to get started, but he has slowed down and done some more reading to see where he went wrong. As I see it, the purpose of this thread is to encourage newbies with no experience to take the time to do their homework and listen to the Frosty and Mikey folks out there to end up in a better place. I never got the impression he was encouraging beginners to ignore experienced advice at all. Mitch, assuming I got the tone of your post correct, keep at it. You're making good progress, but as you've already discovered it does pay to do the research and planning before diving in head first. One other minor point. The tap and die sets you can get at HF are absolute junk in my experience. Unless you think you need an entire set you'd be better off buying quality individual taps you need from a reputable source. Believe me, you'll notice the difference when you use them. A good tap makes it much easier to start the threads and keep them centered. Must be. It sure seemed to me he was expecting to be beaten down by the BIG EGOS who've been making the things. It seemed more like he was encouraging newcomers to read and experiment on their own and NOT ask for help. I guess I fulfilled his expectations eh? You're probably right some days I just shouldn't respond without being asked. It's not like he was asking anything. I'll leave him be. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mitch W. Posted February 24, 2017 Author Share Posted February 24, 2017 Frosty, just the opposite. I would encourage every beginner to read all of your posts since you have have answered TONS of questions regarding your burner and other burners. For example, I didn't read your directions carefully enough when I decided to make your burner, nor did I read the several posts before I asked a question regarding the use of a lathe. I was quickly pointed in the right direction, but could have avoided an embarrassing moment by taking a few minutes to read about the burner and reading the directions more clearly. Maybe I should have stated a little more clearly that I was trying to document my thought process as I was going along, at that moment in time. What I wrote yesterday was a quick snapshot of two months of bad decisions, which could have been easily been recognized if I had relied on more experienced Blacksmiths to coach me along. Half of that time I was mucking along because I had not found this website yet. What I was attempting to point out is how my thought process was wrong BC I had not made a plan, researched what I wanted to build, and to your point rely on some of the other blacksmiths to guide me along. In 2016, you and another forum member had commented on the frustration of helping someone, but not getting any follow-up if it had fixed their problem. That's when I thought to myself that it would cool to document all the bad and good. I know I'm not the only person going about business this way (the wrong way) and I can be a great example of what not to do. Moving forward, I would hope that what I have written clears up any confusion about what I posted earlier, as it was not a direct attack against senior blacksmiths, but more of learning moment on my part. I was the "bad" thought process of thinking I could easily do this with little to no help. Additionally, I was going to post my failed burner in the "T Burner Directions" thread for guidance and not here. It looks like the admins have gone to great lengths to keep all the topics as organized as possible for everyone. I didn't want to start a whole other conversation here when the appropriate place for that conversation is in the thread you started for the directions. Once I found out what I was doing wrong, I bring that back to this thread and summarize/document my steps. If that's the wrong way to do business, then again I have learned something new and anyone new doesn't haven't to follow that step. I'll wait for your response and hopefully I didn't piss you off enough that I won't receive further guidance. I would have done that yesterday but it was 2 in morning. Last, I really wanted to emphasize to new folks they shouldn't be afraid or intimidated to go out and learn something new. I'll be honest, I was bit intimidated after reading through some of these posts. The topics get heated and it can be a bit intimidating to someone new and with very little knowledge of the craft. I don't expect that to resonate with more Sr Smiths, but for someone like me who has very little knowledge, but eager to learn, it was a bit shocking. I guess in my dream world, I expected something different. Luckly, BC I updated my profile like you requested, I was contacted by a local smith and they gave me resources on where to get basic classes. So if I had ignored your advice, I would have missed out on that opportunity. As for the bad humor interlaced within my post, it's just that, humor. Not a direct attack on anyone person. If you felt I was attacking you or any member of the forum personally, I apologize. I'll go back a reread what I wrote and edit any comment you find offensive in nature. Please let me know if you want me to post the failed T Burner in the directions thread. I would love to hear your advice and how to better my basic tool skills and the burner itself. Quote Link to comment Share on other sites More sharing options...
Mitch W. Posted February 24, 2017 Author Share Posted February 24, 2017 Buzzkill, Thanks for encouragement. As for the HF tools, it funny you bring them up. I watched a YouTube video on tools harbor freight sales that you must buy. I didn't know what a tap and die set was, so I googled it and that's what came up. The video made it sound like they were super aweome. It's much like using Wikipedia as a source document, you never know what you will get. I probably drilled 10 holes in my practice pipe before I figured out how to use the darn thing. What set should I buy? I don't mind buying a quality set. It looks like it's a tool commonly used in the craft. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted February 24, 2017 Share Posted February 24, 2017 Buzzkill's advice on the Harbor Freight taps and dies is spot on! Go buy some real taps - they cut well, start well, AND are actually the size they say they are, unlike the Harbor Freight variety. Don't get me wrong though, I love Harbor Freight - for some things, other things, not so much. Just like blacksmithing and a lot of other things in life, you gotta do your research. P.S. That "TON OF EGOS"? ARE the valuable resources of IFI. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted February 24, 2017 Share Posted February 24, 2017 1 hour ago, Mitch W. said: What set should I buy? I don't mind buying a quality set. It looks like it's a tool commonly used in the craft. I have an old set in a wooden box. I don't know the brand name, but I lost a tap and gambled on the HF set. It was more like trying to rub the threads in with friction rather than to cut them. I believe the individual tap I bought afterwards to replace the missing one in my set was Irwin, and I can't even tell you for sure that it's a great brand. I can tell you it's a heck of a lot better than the HF taps though. I know there are people on here with a lot more experience than I have with quality tools of that sort, so hopefully one or more of them will chime in. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 24, 2017 Share Posted February 24, 2017 In general and in the automotive field I have bought 2 larger tap and die sets that have worked well for me. One is Vermont America, and the other is an Irwin set. I like both. I am also no machinist so there are probably better ones out there. I have used both sets quite a bit. Just hope you don't have to buy the broken tap extractor set it's expensive. Quote Link to comment Share on other sites More sharing options...
Mitch W. Posted February 24, 2017 Author Share Posted February 24, 2017 My "Tons of EGO'S" comments is not directed at the grey beards. I think they are an experts for a reason. They dedicated the time to the craft and it should be respected. Without using names, I would give an example of an ego on display for reference. A Sr guy on this forum gave directions on how to build something properly and even gave specific specs. It was very informative. The next post read something like this, "I went ahead and made some modifications to widget x, but I'm having problems with it, can you help?" Sr members tries to figure out why the modifications were needed but the other member could not explain why they did what did. Additionally, they wanted to argue a point with the guy who had spent well over a year creating the darn thing. It was mind blowing! Hence the ego's comment. Some people will not take advice well because it may bruise their ego. So as a new guy coming in with a fresh set of lenses, this caught my eye. I wanted to point out that as a new reader and smith you will see ego's on display that will blow your mind. It had never Occurred to me to challenge or modify a someone's work who is an expert in their field or craft. More importantly, take the comments as constructive criticism because the grey beards know what they are talking about. Had I learned that 2 months ago, I would probably have a forge that actually works, instead of a pile of metal and bricks. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted February 24, 2017 Share Posted February 24, 2017 I prefer spiral point taps because you do not have to back them up to break the chips, just run them in. I did a lot of power tapping in the milling machine and lathe, so the spiral points were a huge plus. There are several types of taps EG; plug, taper, bottoming, pipe, spiral point, spiral flute, forming, etc...and they each have their place. As for what brands-keep it simple and just avoid any that are made in China, India, or the vicinity there of. USA, Japan, Europe are pretty good bets no matter the brand, but even then there are good, better, and best. Cleveland, Brubaker, Ghuring, Greenfield, are a safe bet. MSC, J&L, ENCO, or any other machine shop supplier will have a plethora of taps to choose from. For home use I would suggest either the bright , or black oxide finish. No need for the fancy coating$. Then get a good guality 2 jaw T-style tap handle. I prefer that style over the 4 jaw ones as I get a much better grip on the tap. The flat style of tap handle is also good, but buy quality as the cheap ones come loose while using, handles get loose, and they are just a pain to use. The ratcheting ones can come in handy, but in all of my years of doing machining and maintenance I have only run into a hand full of times that they were necessary. Quote Link to comment Share on other sites More sharing options...
Mitch W. Posted February 24, 2017 Author Share Posted February 24, 2017 Thank you for info on the taps! If you see the the pipe I threaded, you would have thought I tried to do it while standing on my head. It's terrible, but now I don't feel so bad. The pieces were labeled a certain size, but they were not accurate. I ended up buying both an SAE set and a Metric set BC I couldn't get the threds to line up correctly. And then the bit had a really hard time staying in handle BC is is really cheap. I think it's made from recycled coke cans. I'm going to reach out to Frosty again and see if I can work on the method where he uses the drill press to start the threading process. I'll keep this thread updated with the progress. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 25, 2017 Share Posted February 25, 2017 Lighten up Mitch, I have "Curmudgeon" in my header for a reason. Sometimes I just wake up cranky and sometimes I don't know what or why things set me off. I'm getting really tired of blaming the TBI but what is is. I didn't read your post right, didn't know if you were or weren't joking. Frustration comes easy now and anger follows close. Not your fault. I replied to your other post regarding what went wrong and why the jet is wonky. If you have a lathe with a 1"+ pass through then forget the drill press, screw the T on the tube, chuck it up and hand turn it in the lathe. A lathe is the unbeatable best method in a home shop. It's all good. . . I hope. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 25, 2017 Share Posted February 25, 2017 Mitch, one day at work I needed an 18mm crows foot line wrench to replace a power steering line on a vehicle. The " reputable" tool dealer didn't have one on the truck. ( and I had one at home! ) but it was a rush job so I went to harbor freight. They Had crows foot line wrenches. But no 18mm! They skipped it and only had off the wall sizes when that One is common. Ugh! I bought both metric and sae sets. I was despirate. Nothing worked so I ground the closest size under with a 3inch cut off wheel to fit and got the job done. Moral of the story is sure, some tools at harbor freight are great while others will only get you by if they can be modified to work with knowledge or some just don't do the job right. It takes knowledge or experience to know that too. But you know that since you are learning and doing your research. Good luck on your build. Sorry I can't help on that one with zero experience with gas forges. Just tossing out some experiences and hope it helps. I'll keep watching tho. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 25, 2017 Share Posted February 25, 2017 I go to HF for soapstone crayons, cutoff discs, and earplugs. Being on their mailing list, I get regular coupons for "free with any purchase" items, which means I am slowly acquiring a sufficiently large collection of tape measures that I will always have one ready to hand. Quote Link to comment Share on other sites More sharing options...
