Twhitson15 Posted February 23, 2017 Share Posted February 23, 2017 Hi. I am trying to build burners for my future forge, and I don't know where to start. There are so many burner builds on this site and I don't know which is the best one. I am trying to build burners that are somewhat simple but will be great workers. Any suggestions? Link to comment Share on other sites More sharing options...
Glenn Posted February 23, 2017 Share Posted February 23, 2017 Find one YOU like and build it so you can get started. Then you can do more research and either modify your forge and burner or build a second one. One size does not fit all. Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 23, 2017 Share Posted February 23, 2017 Also remember that most questions are pretty useless without the details; we have smiths here where "small stock" means 1' square and others who have forged sewing pins. So how large is this forge, what do you plan to use it for any constraints on building, (no access to welding is a common one). Unusual locations, We've had folks from Iceland and Hawaii here, both suffer from Island syndrome to a degree... Link to comment Share on other sites More sharing options...
Glenn Posted February 23, 2017 Share Posted February 23, 2017 Australians can suffer from island syndrome at times. It is just a bigger island. (grin) Link to comment Share on other sites More sharing options...
swedefiddle Posted February 23, 2017 Share Posted February 23, 2017 No different from the Island called Snorth Hamericah!! Neil Link to comment Share on other sites More sharing options...
D.C. Posted February 23, 2017 Share Posted February 23, 2017 The Frosty t burner is about as simple to build, understand, and tune as it gets. The standard 3/4" build, as shown in his drawings will attain welding heat in a properly insulated forge very easily. Do a Google search for "t-burner iforgeiron" and you'll find the thread with the drawings and compete instructions. Link to comment Share on other sites More sharing options...
VainEnd84 Posted February 23, 2017 Share Posted February 23, 2017 36 minutes ago, D.C. said: The Frosty t burner is about as simple to build, understand, and tune as it gets. The standard 3/4" build, as shown in his drawings will attain welding heat in a properly insulated forge very easily. Do a Google search for "t-burner iforgeiron" and you'll find the thread with the drawings and compete instructions. Or you can just go to the pin near the top of this section of IFI @Twhitson15 the t-burner really is one of the simplest designs and it works really well. But there is no one best burner, it really depends on the type of forge you are going to build and what you want it to do. You are going to have to do some research and figure out your forge design and needs first, this will lead you to what style of burner is going to work for you. Link to comment Share on other sites More sharing options...
D.C. Posted February 23, 2017 Share Posted February 23, 2017 Good catch Vain. Been a while since I've read it. Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 23, 2017 Share Posted February 23, 2017 Well, there might be a single best burner design, but it probably hasn't been invented yet; ditto for such a thing as the single best forge. Link to comment Share on other sites More sharing options...
Twhitson15 Posted February 23, 2017 Author Share Posted February 23, 2017 Thank y'all so much for all of y'alls suggestions. That helps a lot. Link to comment Share on other sites More sharing options...
Please sign in to comment
