ede Posted February 11, 2017 Posted February 11, 2017 I picked up this massive disc yesterday. It was a hub on a gear reducer for a drilling rig in the oil/gas industry. I'm not sure what to do with it, I know it weighs at least 100#'s. I was thinking it could be a base to mount a post vise. However, it has a hollow area underneath. The dimensions are as follows: 23" diameter, 2 1/8 thick base, 3 1/2" overall height, hole size 3/4". When I picked it up yesterday I thought this weighed about a couple hundred pounds. The guy that gave it to me said it's only 75-100. I just weighed it and it it's at 208#! Would this be practical to use as a base for a post vise, or what other uses would this have in a shop? Quote
Mark Ling Posted February 12, 2017 Posted February 12, 2017 What I would do if it is steel and not Cast iron, is I would weld a piece of tubing, weld a plate to the top, but have the plat the correct size so that the leg of the vice fits into one of the those holes that are on the outside of the disk. My vice stand is similar to that, but about half the size! Littleblacksmith Quote
ede Posted February 12, 2017 Author Posted February 12, 2017 Hmmm, I like the idea of having the leg rest in the outer perimeter hole, especially since the outer ring makes flat contact. I will have to see if it is cast or not. Thanks littleblacksmith! Quote
Daswulf Posted February 12, 2017 Posted February 12, 2017 Looks heavy enough. I like the idea of using it as a vise stand as well. Quote
