Ijimmyzw22 Posted February 9, 2017 Share Posted February 9, 2017 Please critique. It's my my fourth knife. Made from an old octagon crowbar. The handle I powder coated flat black. Polished to a high luster. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 9, 2017 Share Posted February 9, 2017 Very cool idea, but the high polish makes it hard to see the blade geometry. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted February 9, 2017 Share Posted February 9, 2017 How well does it work? A crowbar is probably a medium carbon steel since you only want them tough, not brittle hard. Did you do a sample heat treat to see how hard it can get? Nice job on the polishing. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 9, 2017 Share Posted February 9, 2017 Get it wet/slimey and see if your hand wants to slide forward towards the edge when in various uses. What did the original steel spark like? What heat treat did you use? Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted February 9, 2017 Share Posted February 9, 2017 Good Morning, A Shiney object with no finger protection. Neil Quote Link to comment Share on other sites More sharing options...
Ijimmyzw22 Posted February 10, 2017 Author Share Posted February 10, 2017 Thank you for the input. Yes I heat treated with used motor oil and it hardened up nicely. Yes I get the bit about no guard for the blade. Started out just seeing if it would draw out nicely and ended up with this. It feels good in the hand. Thanks again for the input. Quote Link to comment Share on other sites More sharing options...
Will W. Posted February 10, 2017 Share Posted February 10, 2017 As stated, I would mainly just worry about your hand slipping forward during use. It could potentially injure the user. Just as a recommendation for the next one, maybe try grinding/forging/filing finger grooves in? If lined up properly, they make it feel great in the hand too. Just my two cents. Looks pretty good though, nice work. Quote Link to comment Share on other sites More sharing options...
poppaclutch Posted February 11, 2017 Share Posted February 11, 2017 Looks like a slashing tool but first thing I thought of was hand slipping up. Nice looking. Quote Link to comment Share on other sites More sharing options...
