Glenn Posted February 8, 2017 Share Posted February 8, 2017 Ask to sharpen a mattock, a little research came up with the following: Mattock 30*, Another source said 30* each side. Shovel 70* on the dirt side Hoe 80* on the dirt side. or either side, 45* for weeds. Draw knife 33* on one side. The internet is a wonderful place. You can get different answers depending on who does the actual sharpening, and who posts to the web. After a while you start to see similar answers. What angle do you use to sharpen a mattock? Quote Link to comment Share on other sites More sharing options...
gote Posted February 8, 2017 Share Posted February 8, 2017 I tend to use about 20° on one side for draw knives, planes and wood chisels but this is slighty misleading since I grind on a wheel (wet slow going) so the actual cutting angle is slightly less. I then sharpen on a fine flat japanese water stone. or a small diamond sharpener if in a hurry or away from the shop. The slightly concave shape gives a consistent angle (which is again 20°) to the actual edge and very little material is removed in each sharpening. Eventually the convexity is gone and I then grind it back again. It is a little on the idea of a cut throat razor but with much less convexity. I do not use hoes or mattocks but gardening tools get around 30° with no sharpening. These angles work well for me but YMMV Quote Link to comment Share on other sites More sharing options...
John B Posted February 8, 2017 Share Posted February 8, 2017 4 hours ago, Glenn said: Ask to sharpen a mattock, a little research came up with the following: What angle do you use to sharpen a mattock? Angle grinder Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted February 9, 2017 Share Posted February 9, 2017 I think the answer depends on the soil conditions. Chopping through roots in sandy soil would probably call for a "woodworking" bevel, whereas a trench through feldspar might call for "stone cutting" bevel. At this point, I just try to avoid any kind of manual excavation work. Quote Link to comment Share on other sites More sharing options...
