tanglediver Posted February 7, 2017 Share Posted February 7, 2017 While I was going to school for welding, our metallurgy class took a tour of a local steel mill to see how concrete re-enforcing bar is made from scrap. Our instructor spent a very long time to get permission from TAMCO for our benefit, and we were all very impressed by the sheer size of everything. This was some number of years ago, I re-edited my photos into a new video with just a few captions. I hope you enjoy. Link to comment Share on other sites More sharing options...
Donniev Posted February 7, 2017 Share Posted February 7, 2017 I was sent out to help with some welding at a plant that pours steel beams a couple years ago. It was really cool seeing how everything worked, but man I'd come home dirty, soot was everywhere Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 7, 2017 Share Posted February 7, 2017 The MOB once toured a steel casting company that used electric Arc furnaces, 16" diameter graphite electrodes IIRC, 3 per furnace. The tour was in the middle of the night as that's when electricity is cheaper; the dials were calibrated in the *thousands* of amps....Noisy too. The factory had been there since the civil war and their "storage" building was very impressive---I had to point out to my train mad friend that there was actually a locomotive *inside* the building and barely visible amongst the scrapped/stored equipment... Link to comment Share on other sites More sharing options...
Crytin Posted February 8, 2017 Share Posted February 8, 2017 I currently work as Maintenance in an Aluminum foundry that makes cast aluminum engine heads for a major car company. The process to come out with a good usable casting is pretty complex, especially on the scale that we do. We utilize steel dies to create the outside mold and a sand/chemical mixture to create the necessary voids. We use a with 5 60 amp heaters to keep the aluminum molten. and water to ensure the aluminum solidifies at the proper rate to ensure a solid casting. there's ALOT more that goes on and I can go into further detail if anyone needs but we strictly deal with aluminum, so I have no experience with steel, though I'm sure some of the process is the same, depending on the scale of the steel being cast. Link to comment Share on other sites More sharing options...
JHCC Posted February 8, 2017 Share Posted February 8, 2017 5 hours ago, Crytin said: I currently work as Maintenance in an Aluminum foundry that makes cast aluminum engine heads for a major car company. The process to come out with a good usable casting is pretty complex, especially on the scale that we do. We utilize steel dies to create the outside mold and a sand/chemical mixture to create the necessary voids. We use a with 5 60 amp heaters to keep the aluminum molten. and water to ensure the aluminum solidifies at the proper rate to ensure a solid casting. there's ALOT more that goes on and I can go into further detail if anyone needs but we strictly deal with aluminum, so I have no experience with steel, though I'm sure some of the process is the same, depending on the scale of the steel being cast. Speaking of Aluminum, the college where I work has as one of its alumni the fellow who developed the electrolytic process for extracting aluminum from bauxite, making aluminum production commercially viable. Link to comment Share on other sites More sharing options...
Please sign in to comment
