angiolino Posted February 3, 2017 Share Posted February 3, 2017 hello, I know I should appeal to a technical, engineer, architect, surveyor or structural engineer or higher, but I should make a cost estimate what you think? http://www.cad3d.it/forum1/attachment.php?attachmentid=44416&d=1467874497&thumb=1 http://www.cad3d.it/forum1/attachment.php?attachmentid=44416&d=1467874497&thumb=1 http://www.cad3d.it/forum1/attachment.php?attachmentid=44418&d=1467874954&thumb=1 ho anche fatto i conti della massaio, in linea di massima se manca qualche cosa ti invito a sottolinearmeloElenco materiali:1) N°6 pilastri esterni h= 2,80+ 3 pilastri interni 3,80 hea 1206x2,80= 16,8 m 3,80x3 =11,4 mTotale 11,4+16,8 = 28,2 metri x 19,9= 561kg pesoCapriata:14,02x n° 4 = 56 metri ipe 12056x10,04 kg/m= 582,4 kgArcherecci correnti = sezione 50x30x 1,5 mm17 m x 14 pezzi = 238 metri238x 4,27kg/m= 1016,26 kgCatene di controspinta14 metri x 4 pezzi= 48,4 metriProfilato ad U 100x50 = 10,6 kg m48,4x10,6 kg /m =513,04 kgTotale kg=2672,88 kg I also did the accounts of the steward, in principle, it lacks something I encourage you to sottolinearmelo Materials List: 1) # 6 external pillars h = 3 2,80+ inner pillars 120 3.80 hea 6x2,80 = 16.8 m 3,80x3 = 11.4 m Total 11.4 + 16.8 = 28.2 meters x 19.9 = 561kg weight truss: 14,02x No. 4 = 56 meters ipe 120 56x10,04 kg / m = 582.4 kg current Archerecci section = 50x30x 1.5 mm 17 m x 14 pieces = 238 meters 238x 4,27kg / m = 1016.26 kg Chains of counterforce 14 meters x 4 pieces = 48.4 meters U section 100x50 = 10.6 kg m 48,4x10,6 kg / m = 513.04 kg Total kg = 2672.88 kg what do you think, how you costruireste empirically, what do you think, where I went wrong thanks for your attention and technical advice http://www.cad3d.it/forum1/attachment.php?attachmentid=44432&d=1467907582 Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 3, 2017 Share Posted February 3, 2017 Winds and snow load? Cross bracing to prevent racking? Do you have the scaffolding and lifting equipment to work on it or will it need to be rented? Crew? Permits cost? Quote Link to comment Share on other sites More sharing options...
angiolino Posted January 30, 2018 Author Share Posted January 30, 2018 i the wind and thunderstorms are a problem does not snow the building is at sea level you need to rent hydraulic crane set up on a truck to hoist and lift the various materials and tools, to the jib crane you hook a special basket to perform work at height Quote Link to comment Share on other sites More sharing options...
