Christopher Lawrence Posted January 26, 2017 Share Posted January 26, 2017 So, I have a piece of rail to use as an anvil. What I do not have is something to use as a horn. It occurred to me since I was going to use a horn primary for shaping that a large Dock Cleat would work. I was talking to a friend of mine about my idea and he happens to have one that he will give me. Below are the pictures. As you can see the center section is hollow and a rusted though in places but I think the cleat over all is still sound. The idea is to clean it, mount it and grind one of the two horns into a taper. The other side I will smooth out but not alter for larger bends. Thoughts? Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted January 27, 2017 Share Posted January 27, 2017 Not to be flippant, but why do you need a horn? I rarely use the horns on my anvils, and up until say 250 years ago anvils didn't have horns. Quote Link to comment Share on other sites More sharing options...
JHCC Posted January 27, 2017 Share Posted January 27, 2017 Can't quite tell from the photo, but the cleat looks (A) cast and (B) with some rusted-through voids in the middle. Might not stand up to heavy hammering. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted January 27, 2017 Share Posted January 27, 2017 I say if it's free, and you have the time give it a shot. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted January 27, 2017 Share Posted January 27, 2017 It also wouldn't be too hard to taper one end if you so desire. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 27, 2017 Share Posted January 27, 2017 Probably not rusted though as much as casting voids and probably cast iron. I have one myself for armour work, (and how a large cleat came to be in a scrapyard in the desert with no body of water large enough to float a boat to use it in the State is a puzzlement! My bet is a retired Navy guy's yard decoration...) Quote Link to comment Share on other sites More sharing options...
Tommytaptap Posted January 27, 2017 Share Posted January 27, 2017 And a pair, yes a pair of ready made hardie/pritchel holes. You can't have enough of those. Me, I would leave it as it is apart from a good flapwheel clean up and use it. Quote Link to comment Share on other sites More sharing options...
Christopher Lawrence Posted January 27, 2017 Author Share Posted January 27, 2017 Thank you all! Tommy - I had not even considered using the cutouts as hardie holes Thomas - Probably one of my Boatswains Mate brothers C-1 - That is the plan Daswulf - Free is always good JHCC - Agreed. Wanted it more for shaping. BigGunDoctor - I am thinking of thinks like S hooks. (Note - I do not have something to use as a hardie hole to hold a jig) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 27, 2017 Share Posted January 27, 2017 I've seen some anchor chain out here but that has a known use----drag it between two large bulldozers to clean scrub pastureland up a bit. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted January 27, 2017 Share Posted January 27, 2017 As for the s-hooks, those can be done right off of a flat face. Most of the scrolling I do is very small, and tight, so the horn is not even considered. I mainly use the horn as a large radius fuller. A simple bick would be easier to make than grinding that cleat down. Being cast I would leave the cleat as is, and look at making a bick that drops into it. Quote Link to comment Share on other sites More sharing options...
Christopher Lawrence Posted January 27, 2017 Author Share Posted January 27, 2017 BigGun - That makes a lot of sense. I need a lot of practice on scrolling. Now that Tommy mentioned using those mounting holes as hardy hardy holes, making a bick or a hardy tool for the curve is probably best. Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted January 27, 2017 Share Posted January 27, 2017 A few things that i might do if i didn't have a horn or a London pattern anvil- -first thing I would do is to do my bends over the edge of the anvil. It will take some practice, but once you got it, there is basically no use for a horn. A horn is just something that you run into and wish you never did. -I would also make a portable hardy hole, or some other hardy hole alternative. That way I could make a hardy horn (basically a tapered bar that fits into the hardy hole. for larger curves obviously a large horn, and for smaller ones you could use a smaller one). If I did make a hardy bick I wouldn't do all of my bending on it. I would probably start my bend over the edge of the anvil, and then true it up on the bick. -Also if I had some sort of makeshift hardy hole (or even a vice) I would make a series of bending jigs. Even I, who has a horn has more than one bendin jig. They are great if you are doing any bit of production work (or even if your not) or if you are trying to get more than one bend, and are wanting them to be the same, Ex. an S hook. Not only that but they are quicker, or at least for me they are quicker most times, compared to using the horn. I'm not saying not to ever make bends and curves over the edge of the anvil or on a horn, because it is a very important skill to have. Also, you cant bend everything in a jig. Well, you probably could, but that would be a lot of jigs! when I started typing this I thought I had another alternative, but now I cant remember it..... Littleblacksmith Quote Link to comment Share on other sites More sharing options...
gote Posted February 2, 2017 Share Posted February 2, 2017 A European style horn is quite useful for getting bends right. Mainly for increasing the diameter of the bend. I recently straightened some scrap iron that was thightly coiled and the horn made it very easy. I have never run into a horn but it might be a case of shop layout. Ths is just another case of the two blacksmiths giving five different answers on how to do something. Quote Link to comment Share on other sites More sharing options...
