Forgingnoob Posted January 26, 2017 Share Posted January 26, 2017 I have very little electrical know how. Do any of you guys mind lending me a hand on what I need to do to get this motor running Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 26, 2017 Share Posted January 26, 2017 Well first you have to tell us if you will be running it on 110 or on 220. Quote Link to comment Share on other sites More sharing options...
Forgingnoob Posted January 26, 2017 Author Share Posted January 26, 2017 110 Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted January 26, 2017 Share Posted January 26, 2017 green wire to the case of the motor, black : connected to wires marked 1,3 and 5 white : connected o the wires marked 2,4, and 6 make sure to tape over all exposed connections and replace cover. Black wire should have a on/off switch House light switch works fine if you dont have anything else Quote Link to comment Share on other sites More sharing options...
Forgingnoob Posted January 26, 2017 Author Share Posted January 26, 2017 Thank you very much steve. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted January 26, 2017 Share Posted January 26, 2017 And as the label says - to reverse rotation swap wires 5 and 6 (or 8?). In the photo, it's hard to tell if that's a 6 or an 8. I thought 8 at first glance. Quote Link to comment Share on other sites More sharing options...
Forgingnoob Posted January 27, 2017 Author Share Posted January 27, 2017 It's and 8 the label is rubbed a bit there. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted January 27, 2017 Share Posted January 27, 2017 then where are 6 and 7, and what do you do with them ? Have a nice day Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 27, 2017 Share Posted January 27, 2017 On January 25, 2017 at 10:15 PM, Forgingnoob said: I have very little electrical know how. Do any of you guys mind lending me a hand on what I need to do to get this motor running It may be time to take the motor to a shop in your area. They can show you how to wire the motor up, answer all your questions, and bench test it if it is needed, No shops locally, then contact the manufacturer. They know the motor and how to make it work for you. Quote Link to comment Share on other sites More sharing options...
Forgingnoob Posted January 29, 2017 Author Share Posted January 29, 2017 On 1/27/2017 at 8:10 AM, Steve Sells said: then where are 6 and 7, and what do you do with them ? Have a nice day 6 is a ground I believe and im not sure what 7 does. Quote Link to comment Share on other sites More sharing options...
