littleblacksmith
I agree with Slag; what a great hold-down! Simple and effective. And a wonderful moustache too, Mr Stash. :D
Share this post
Link to post
(Blush) you all are too kind. Thx. Indeed a good time was had by all. It was a pleasure to break bread and burn coal with you,John, and the forge is open whenever you're in the area. I never told you- the hold down was a chunk of buggy wheel axle. Once I had my way with the wheel, that was all that was left. 1 1/4"round steel with a 90 degree bend in it, and I had a lightbulb moment. I usually go for that above all my other hold downs.
Steve
In 37 years of marriage, my wife has never seen my upper lip.
Share this post
Link to post
I made some progress on my swage block stand, though I ran out of time. I'll have to try to finish it next week. I ran the rough-sawn 4x4s through the jointer to get a good fit-up and started boring holes. The plan is to run 1/2" all-thread through the blocks in both directions to help hold everything together.
Share this post
Link to post
I love your ghosty things CGL. Clean simple and very expressive.
Well done. Frosty The Lucky.
Share this post
Link to post
Thanks Frosty. My interpretation of what I saw made. You put a candle in front of them and they cast a dancing shadow on the wall. ^_^
Share this post
Link to post
Finally got the tree down. Windy day made it scary. Can finally start constructing the shop. I also pulled apart my first cv axle. I think that’s what it’s called. I must say, the parts are pretty cool. What does one do with them? Could the housing hold up as a dishing tool?
Share this post
Link to post
I made my daughter a bracelet from the retaining ring:
Share this post
Link to post
yes, the outer housing part can be used as a dishing tool. All the parts inside are good quality carbon steel and can be used to good merit. I would shape the axle stub part while it's still pretty easy to hold.  I usually cut off the outer ring part and this is good chisel or knife stock.
Share this post
Link to post
Sorry, having issues with posting. Nice bracelet. That was my initial idea. JLP do you mean the bracelet looking thing that seats the bearings as good knife/chisel stock? Thanks for the responses!
Share this post
Link to post
It's all good steel and they are all hardened pieces.
The larger cup piece is called the cup and it has the stub shaft.
there is a ring on the outside of the cup to hold the dust boot.  I cut these off which gives me about 1-1.5" of a round slide of the cup.  I then cut this ring on one side and open it up.
I use an abrasive cutoff blade.
What I do is forge the splined shaft down before I cut the cup off.  the rounded inside section makes it very hard to hold while forging the shank to fit the hardie hole.
Share this post
Link to post
671, That toothed wheel thingo would make a great little scrap owl for your daughter.
Share this post
Link to post
A week ago I bought a big (at least for me) post vise in need of some work for $65, and today I'm just about done fixing it. It was missing its mounting plate, wedges, and spring, so I made all those. I also straightened leg, which was bent. It weighs 110lbs, and has 6 1/4" jaws.
The threads are worn, but I'm hopeful that they'll still last a long time now that it's all cleaned and lubricated. The only marking I was able to find on it was an "AA" stamped on the front leg.
Share this post
Link to post
Thanks for the tips JLP. Btw, I really enjoy your instructionals on YTUBE. Very helpful for a beginner with no teacher.
Thanks Aus. You do some sweet work! I actually have a son (7yrs) who is pretty interested in almost everything i do. We have already made a small blade together and are working on a prop  jet pack. Most forging is on hold until the shop gets built.
That is a beast. upsetting would be nice in that.
Share this post
Link to post
Technically it is a CV shaft, but that is just nit picky. CV, for those who do not know, stands for constant velocity.
Do you have the whole axle? That end goes into the wheel hub assembly, check the tranny end and see if there is not just a sheet metal plug in it. If so i have drilled a hole through them so that a piece of thin metal could be place inside it. Then on one end a string and the other end a knocker for a bell. I used one of the bearings for the knocker. They actually have a nice sound and are quite loud. Since moving last winter i have not been able to locate the one that goes on my porch. When i do i will post a pic.
Not all of them have a "female" end nor a sheet metal plug. GM the drivers side is like that, while the passenger side has a "male" end going into the tranns. Some of them are a real pain in the ... to get apart. I have whaled on them with a 10# sledge and they aint budged. Most of them were European cars.
I just realized that you do indeed do have have the whole thing. You are showing the tripod bearing and the Rzeppa joint.
Edited by BillyBones
spelling error
Share this post
Link to post
Some of the projects from the last week.
First attempt at a leaf, horseshoe heart.  Broke one heart and turned it into two hoof picks.
Edited by BEJ431
Added pic.
Share this post
Link to post
Started cleaning up an old plane that was my granddad's. It's pretty rusty so i been soaking it in oil for about 3 days now to get it apart. Just an old Stanley but there is a little sentimental value behind it.
Share this post
Link to post
I used to have a Stanley 45 combination plane that was my stepdads. I never did figure out everything you could use it for. I don't know what ever happened to it.
Pnut
Share this post
Link to post
My grandpa was quite the accomplished carpenter and cabinet maker. I have a bunch of his old tools. Thanks to someone here on the anvil stand thread i learned that some of the drill bits i have are bell hangers bits. I also have a couple adjustable drill bits.
Share this post
Link to post
My first foray into split bar work. Both are from spikes, the Celtic cross was hot cut the other on a bandsaw. Lots of room for improvement but I'm happy with the first attempt.
Oh yeah, the stars aligned and the ring is forge welded.
Share this post
Link to post
Thanks CGL, of course I had to post right before Alexendr. That is some amazing work.
Share this post
Link to post
