littleblacksmith
The Theater Department lets me use their welder in exchange for my doing a guest lecture on basic fundraising principles for their Theater 240 (Introduction to Arts Management) class. When they know they're not going to need it for a while, they'll even let me take it home until they need it again.
Share this post
Link to post
JHCC, when they need it or can't find it just tell them to act like they have one.
Share this post
Link to post
That only works with actors. Techies are an entirely different breed.
Share this post
Link to post
Got the third cross made for my aunts coat rack. They all need a little tweeking and some sander work but most of the forging is done. The nails still need the heads oriented and the same, some tweeking and sanding. I got them laid out on a piece of oak i may use, have a piece of walnut also. Dont knw which i would prefer, but thats a while away.
So that i got some time on. So i wondered what else can i do? rummaging thriugh my scrap i found it. When i first started trying tongs a made some mistakes, this one turned out useful. I mashed the jaws out and made some of those "bottle opener" tongs. I think i owe the inspiration to Jennifer, so thanks for that.
If you look at the boss you will see where i made my mistake. I even punched them before i realized. But they may just work with a little more tweeking and fidely work.
Share this post
Link to post
Haha nice friend Billy
after showing off my last drive hook, Jenifer reminded me to upset the struck end. I did so and am much happier with the result - thanks Jen
Also finished forging my hot cut. Bad photo   Did some other stuff in 4 hours. Lots of fun. !
Share this post
Link to post
Good Morning Billy,
You didn't make a mistake, you were making tongs to hold the "Inside" of a piecce of Pipe or Tubing. Those pieces should be kept so you can hang them on the "Wall of Learning", look back in 10 years or so and smile!!!!  Or, use them for what you intended for them to work. Perspective, Perspective, Perspective, No Mistakes, just unforseen conclusions!!!
Neil
Share this post
Link to post
19 hours ago, Dax Hewitt said:
I thought that would be the case but they look so well finished I can't get my head round how you would get round them on the anvil being so close to the head
You split the metal and bend them out first. Then fold the head back and shape the nose, add the mouth, nostrils, eyes while the horns are still short and square. The head is then placed nose down over the side of the anvil and the horn is drawn out towards the anvil centre. They are kept square until desired length is achieved and then rounded off gently.
Share this post
Link to post
When i forge drive hooks I bend the pointed end a Little past horizontal. I read somewhere that it helps lock the hook down when you hang something from it and I've been doing it that way ever since. I haven't tested between the two but it sounds right to me. Just slightly past perpendicular to the wall or beam it's going to be hung from. I don't have any pics or any hooks left seems like I give them away as soon as I make em. I'll post some pics as soon as I'm allowed to light the forge again.
Pnut
Share this post
Link to post
Doddle then. I will knock out 20 on Saturday :)
Share this post
Link to post
In the process of reorganizing my wood shop (as if it were organized to begin with) to fit a forging station. Winter is just around the corner here. Working in the unheated garage doesn't sound like a lot of fun.
With a little guidance from Jim, I got my pumper forge running correctly. I prefer the dirt forge for actual play time, but it was fun project to make it operational.
I finished a hot chisel and an object that has a vague Calla Lily like shape.
Share this post
Link to post
BillyBones - I experimented with crosses like that a while ago, and I liked the look of making dimples all over with a small ball-pein hammer, then shining them up a little with a cup wire wheel.  Also did some where I thinned out and widened the arms towards the ends and then dimpled/shined them and that looked good, too.  Gave them a little more organic shape and a little more visual interest, I thought.  -- Dave
Share this post
Link to post
Dave, i like those ideas. Would be a little more interesting. My aunt is very religious and this is supposed to represent the crucifixion. So i want to keep them as simple as possible.  They do still need some tweaking and maybe i will flare the ends some, but everything can now be done with a torch.
Share this post
Link to post
Billy, the crosses look good, I texture some like Woodnmetal said and do some with a small cross pien to give them a wooden texture.
Share this post
Link to post
Billy, your crosses look good and your aunt will love them.
Here are a couple of ideas you may like to try sometime:
Share this post
Link to post
I really like those presentations, ausfire.  Good lookin' crosses.  Nice work.  I especially like the woodgrain concept.  Is that done with a textured hammer head?
Chris
Share this post
Link to post
Aus, i love the Celtic style ones. I have seen the Fredrickscross opened up to make the ring, but these are he first with both.
I am a sucker for the Celtic Cross. My Rosary has a Celtic Cross on it. My family is from Ireland and i try and celebrate that every night with a couple pints. :D
Share this post
Link to post
Disassembled and cleaned most of the parts for the vise I got over the weekend. For example:
Share this post
Link to post
first try at a laminated blade, file sandwitched between your average lawnmower blade. scored a bunch of them from a buddy, in hindsight i woulda used something else. a bit too thin for only 3 layers me thinks... anyway i hardened well altho there is one small section on the spine that has delaminated a pretty noticable amount while i think is still functional for personal use im highly tempted to scrap it but ill most likely slap a quick handle on it and run it thru some strength tests as ive been wanted to do that. that way i stand to gain some actuall insight on my work
any feedback is welcomed.
Share this post
Link to post
Yes. Easy to make. Find an old hammer and make random strokes across the face with a fine cutting wheel or similar. Helps if it's domed a bit.
Share this post
Link to post
cheechwizard.  nice job.  Many have a hard time doing that kind of weldup especially for their first time.  Many have a problem also in the forging to shape of the blade when welded this way.
Share this post
Link to post
Clamp the delam In the vise and test the portion in front of it if the delamination is towards the handle. I haven't had much luck with mower blades. I think older ones might be better. I got a few from a repair place up the road from me and I didn't like them much. They were newer though. I found an old push mower. I can't think of what they're called. The kind with no motor. The blades on it sparked like medium/ high carbon.  I think I read newer mower blades are alloyed with boron but don't quote me on that.
Pnut
Share this post
Link to post
