littleblacksmith
The disk failure came while I was cutting up the rack. I don't yet have a motor for the cutoff, which was one reason it was so cheap ($14.40). I'm thinking about how I want to set it up, and I'm probably going to start another thread about that.
Share this post
Link to post
And here it is:
Share this post
Link to post
John: Next time you want to cut up something made of tubing how about using a SawzAll? I have a Portercable Tigersaw, even uses the same blades. I see SawzAlls at the surplus site all the time, the battery driven ones are a gamble but an inverter so you can run a 120v AC saw isn't expensive and you see them surplused now and then too.
Thinking about it just now you see trailers of all kinds some pretty small, ATV hauler size. No reason not to have shop shelving indoors and out made up from flow racks, heck make a garage you can roll over the trailer. Hmmm?
I went through a similar spate of build ideas in the day it cost more to ship ATV crate frames back to the importer than they were worth. The dealer would stack them outside the fence next to the dumpster so I stopped in and loaded pickup beds full till I got tired of lifting the things. Lots of darned handy light wall square and rectangular tubing.
Share this post
Link to post
Alexandr, you are both a wonder and a curse. I showed images of some of your work to my wife, and she said "Why don't you do things like that out in your shop, honey?". Sheesh. I have no words to describe how amazing your work is. A treat for the eyes.
Share this post
Link to post
Thanks buddy.
A short video. I don’t know if there is music or not.
Share this post
Link to post
Alexandr:  As always, lovely, lovely work.  I do have 2 questions: (1) are the chains commercially manufactured or are they the product of your shop? (2) how is the chandelier wired?
Share this post
Link to post
I buy chains. I install electricity myself.
Share this post
Link to post
Alexandr,
Thank you.  That helps to understand the construction.  The wiring appears to be almost as complex as the iron work.  It is very well hidden.
Share this post
Link to post
Neat back scratcher. I've done a couple by hand but it's hard work drawing them out. Power hammer??
Share this post
Link to post
Aus, funny you say this.  We are blacksmiths after all and swinging a hammer is what we do...
Using proper technique makes this pretty easy to do. As easy as a power hammer,  certainly not.
But, with experience larger pieces of stock get easier to forge.
When I first started 1/2" was tough, this migrated to 5/8" and 3/4 " is the change point I find for most..
Now 1" or a combined measurement that equals 1" is pretty easy.
Point is experience plays in and people should keep that in mind. Getting good at smaller sizes of stock forging can pay off as time and skills gets applied to larger sizes.
Share this post
Link to post
Even funnier, Jennifer. I was watching one of your videos yesterday and I was telling my husband how you work such large pieces of stock by hand and make it look pretty easy. I have several 2 ft. 1/2" pieces of round stock that I haven't really touched much. I used some just to practice skills on last weekend. It's not the easiest, but then it gave me the idea to make some hangers for my gate posts to hang lights from. I made two nearly matching pieces. Need to tweak them a little and finish them up. Anyway, as I've been working these pieces, I was adjusting from one heat to another and learned quite a bit in the process. And my swing was improving and getting harder as I went. I was thinking after this, smaller stock may seem like a breeze:)
Share this post
Link to post
CGL,  That for sure is some wise words..
Keep at it and you are correct after the 1/2" the smaller sizes will seem easier and more manageable. .   Every once in awhile it's a great idea to pull out a larger size stock and spend some good amount of time with it.   1hr, 2hrs what ever you feel comfortable doing.. then take the rest of the day off and work some smaller stock the next day or two giving yourself enough time to heal and process what that size stock was like.
3/4" as I pointed out is the ( marginal way)..    it will be tough as a secret that needs telling. :)   I found 3/4" tough for maybe 7 years. Of course I started when I was 8.. LOL.. Even then I would try other things to avoid forging such heavy stock.  Tongs is what got me to work with it on a regular basis.  3/4"Sq is the standard flat jaw tong stock.
One other thing I wanted to mention. Is, Don't just pick easy shapes after a 3 or 4 times on the heavier stock.  Pick something that actually takes some thinking to make.  Pull out an ear, or do a T or something like that. A fork, spoon, ladle. something that will test your metal (chuckle, chuckle) but one can put down and pick it back up later to work on again.
By the way 1/4x3/4 or 1/4X1" is considered my most hardware smiths to be the main sized material for nearly all forks, spoon, ladles,  and a good majority of thumblatches.
Share this post
Link to post
Well, I'm a lot older than 8 for sure;) I spent about 4 hours working on that stuff the other day and I could sure tell it afterwards. I wish I could get out there more often than I do to stay in better shape. I found more 1/2" that I didn't realize I had in my scrap pile, so more practice. I will take your advice and go for more varied shapes also. The first pieces I practiced squaring, rounding, scrolling,  tapering, twisting, flattening and spreading. And hammer swing and control. It was a good day in the shop for a change. And I will continue to do so. I do have larger stock, and I'll work my way up to that but am in no big hurry. Thanks for the advice. I appreciate it as I'm sure many others do as well
Share this post
Link to post
The better your hand hammer techniques are will be of great benefit when you come to use a powerhammer.
Many go the powerham before understanding how the metal reacts under a hammer.
Share this post
Link to post
Ausfire, no power hammer here. All hand drawn. It's nearly down to 1/4" in the shaft, left a little more meat on the handle area. Overall length is about 14". I usually carry a tape measure on my pocket, so I stretched it out a bit and  reached over my back. 14" seemed to hit all the hard to reach areas. I have a few friends who work for the RR, so I was looking for trading stock to get a few more spikes.
Here's a better pic of the Business End of it...
Share this post
Link to post
John B, I think when you are new to the craft, you don't realize how important it is to understand how the metal moves and how to make it move. You just get focused on making a thing, whatever it may be. And that becomes your goal. I just recently really came to think this way myself, so I'm definitely not speaking for anyone else. If I don't actually make or complete a specific project for awhile, I'm ok with that. I want to really learn the process and understand it. Hope all that makes sense. I've never even been around a power hammer, but I can imagine it would be much more effective if you know how to move the metal to begin with. Thanks for that piece of wisdom. Glenn II, nice job drawing that spike out like that. I have several of those and haven't even attempted to do anything with them yet.
Share this post
Link to post
I managed to get 800mm out of a 5/8" rail spike by hand, but it was hard work and I don't really know why I did it. The back scratcher in this photo is about 500mm long.  Not as elegant as Glenn's. but it works!
Share this post
Link to post
Elegant is hardly the word which I would use to describe it, but I thank you Ausfire and humbly accept your compliment. Also I screenshot your pic of RR spike builds. I can do/make plenty of things, but lack the much of the creativity during the design phase of a project. I'm not really the "idea man" on a project. Sometimes I start with a planned project in mind, other times I light the forge, heat some metal, and wait to see what developes. Sometimes I tell the metal what to do, and sometimes I listen as it tells me what it wants to do. Sometimes I tell the metal where to go, other times I follow as it leads me.
Share this post
Link to post
