littleblacksmith
10 hours ago, Laynne said:
JHCC, more pics of the Mason jar handle please. I've not seen those.
Laynne
Share this post
Link to post
Jhcc,
That's so cool. I might have to give that a try. Folk round here would love that.
Pnut,
Definatly too much. But she laughs at it now and it has turned into a running joke played on each of the younger females in the family the first time they get preggers. Though we now let them in that its a joke after a few minutes.
Share this post
Link to post
Made my first damascus project this weekend. I started out with chainsaw chain and ended up with a small knife. It was a fun Little project. Still need to get the hang on making handels and scabbards. I ended up with a little gap between the knife and the scabbard
Share this post
Link to post
Eventlessbox, that was the funniest thing I've heard in a while. I'm smiling thinking about it.
Pnut (Mike)
Share this post
Link to post
JHCC, thanks for the additional pictures. That's what I envisioned, also did a web search and looked at the images. Thanks again.
Share this post
Link to post
On ‎4‎/‎27‎/‎2019 at 12:05 AM, ThomasPowers said:
Forge a punch to make the eyepunch. Drill a void in that punch before hardening. However a small cone in the eyepunch will overheat and wear fast.  Why not just use a separate punch to make the pupil?
Yes, that's the way I have always done them. The thing is - with a domed punch to make the eye, it is very easy for the second punch to slip off the domed surface. You don't want cross-eyed ram. I get most of them right, but just thought there may be an easier way.
Recently with rams I have given them a slotted pupil and that's easier, but with longhorn bulls they still need a round eye spot.
Share this post
Link to post
ELB; I think I'd rather climb in a wooden barrel full of bobcats and rattlesnakes and have it set on fire and rolled down a 3 mile, 25% grade hill than mess with a Pregnant Woman.   OTOH rubbing my wife's feet and back produced comments like "turn down your halo the glare is starting to annoy the next town over!"
Share this post
Link to post
Made my first real hook and then tried my hand at a couple of horseshoe hoof picks. Built a spring fuller to isolate the end for drawing out. Need to work on symmetry when drawing out but it’s coming.
Share this post
Link to post
That's what spacers are for. I use felt and epoxy, felt comes in paper sized sheets at the local sewing and craft supply. Jo Anne's fabrics by name. I just pressed blanks between a counter top and a brick with wax paper as a release agent. I chose grass green but the color selection is huge. Paper and epoxy works just fine too. Years ago an acquaintance was collecting dryer lint, pressing and gluing it for lamp shades. Just wash and dry the right color blankets or just pick one from Salvation Army and cut it up. Hmmm?
Not a bad blade by the way, you got a nice pattern.
Share this post
Link to post
On 4/28/2019 at 2:14 AM, Frosty said:
Nice stock rack Fowllife. Are those galvy guard rail posts on the bottom?
Yeah, guardrail post for the base, and an old I beam for the upright.
I finally had a few minutes to fire the forge up today. I’m ashamed to admit it’s the first time in probably 3 months or more, just been too busy with other stuff. After my second failed attempt at forge welding I decided to switch gears and make a second go at some bottle openers. Making some progress, but need a little more refining.
Share this post
Link to post
Progress, not perfection. I had an almost thirty YEAR drought once, so three months is no big deal.
Share this post
Link to post
Something a bit different. Made a "1" ricecrispie treat cutter for Elizabeth to make favours for my daughters party this weekend. Also my first cookie cutter. Made in stainless steel. Certainly learned some things. A little more cleanup and its ready for trial.
Took forever to find my old saw blade sharpening vise that I knew I had to do the main bending. Lol, it was right in front of me a few times looking. Time to get this place organized tor the thousanth time.
Share this post
Link to post
Nice work.  It's great you have a saw sharpeners vise to even pull out to use.  Most don't have a clue what this tools is even used for.
How do you like the portable belt grinder?
Share this post
Link to post
It's a cool vise, and it worked out bending this stainless sheet around.  I absolutely love the little belt grinder. I got one for work to grind welds, and liked it so much that I just had to get one for home as well.
Share this post
Link to post
In the process of making the stand for my leg vise finally. I've got these two big brackets I'm welding to some 3/16" steel and I'm gonna bolt the beam to them. Thinking about using something to run from the beam to the brackets to tighten them up for extra security. I can never remember what they are called. The things that you turn the middle piece to tighten the screws on either end.
Share this post
Link to post
That's it
Idk why I can never remember what they are called. Just ran some nice beads on this with the stick welder if I do say so my self.
Share this post
Link to post
They look like they will hold up. :) interested to see the finished stand. Are you going to weld on something to set the bottom of the leg into?
Share this post
Link to post
And I'm gonna set the leg in something. Not sure what yet. Looking for stuff with the right size hole already in it.
Now I've gotta cut my piece of wood to the right length and I'm almost finished.
Share this post
Link to post
When I made my stand, I didn't have the right piece of pipe to fit the end in. However, I realized that it was the flat plate the bottom of the foot was resting on that was absorbing the force of the blows; the pipe was just to keep it from sliding around. I therefore welded three little blocks around where the foot rests, which do a perfectly fine job. I've since acquired the right piece of pipe, but it hasn't been worth the bother to make the change.
Share this post
Link to post
For my travel vise I once used  a hand tamper without the handle for the acorn to fit into.  Then just held that in place with some tent stakes.
Share this post
Link to post
Alright. Other than securing the bottom of the leg I finished it. I think I might go back here in a bit but I've been at it since like 9. Should I leave the base as is or should I take a little length off. I think it's good since I can stand on it though.
Share this post
Link to post
Leave it long so you can stand on it while working. It'll be more stable.
Share this post
Link to post
Definitely leave it long, it's kind of narrow so you'll need all the stability you can get. Just wrap a piece of rod around the pin on the end of the leg and weld it(the RING!) to the plate. The vise can hold it in place while you tack it. Just be careful NOT to weld the vise to the stand too. hmmmm? ;)
Looking pretty good, keep at it.
Share this post
Link to post
