littleblacksmith
Why is it all long time blacksmith's hands all look the same..
Most of the really old ones are faded some now or covered by newer ones.
Did you get a new MSI computer?
Share this post
Link to post
Inventorying the scars on my hands helps keep me awake during long boring meetings in my day job! Molten zinc and a 160# Great Dane are two of the odder ones; though I like the semilunar pipe scar---I tell folks it's a secret society brand...and oh yes the crushed pinkie and the license plate scar(thrown).
Share this post
Link to post
I call them initiation marks into a very special club.  ;)  And the difference between a blacksmith and anyone else is that the blacksmith doesn't flinch and screw up the forge weld!
Share this post
Link to post
My scars disappear pretty quickly unless they're deep. Lack of hair on the other hand, either hand actually is the norm, I think it's just stopped trying.
I know I'm on fire. STOP SLAPPING ME!! The smell of cotton smoke is distinctive, leather and wool are REAL attention getters. Seared pork is more subtle but the other clues suffice.
Be careful out there.
Share this post
Link to post
2 hours ago, anvil said:
wI call them initiation marks into a very special club.
one of my good friends came over back when i was making the steeled 4+lbs wrought iron hammer. I was hoping he could help me at least get a tack on them.
 I told him it would be hot and not to worry its just radiation heat from the hot metal so not to be surprised when I pulled it out and be ready to hit it with the sledge very lightly to set the weld.
I pulled the 2 pieces out and he jumped back..  I was like where are you going..    " He looked at me and said paraphrasing " it's skunking bunking hot, I now know what a pig feels like going into the oven"   He immediately thrusted both arms into the water bucket.
I cleaned up the 2 pieces and put them on the side and shut the forge down..  It wasn't THAT hot...
Share this post
Link to post
Chelonian- I believe that is what is known  (at least in my area) as a mason's 'point'. It is used for trimming down bumps and lumps on stone surfaces. High carbon, make what you want from them. Probably treat it as 1080 or so. I just got a bunch of them at a barn sale- great stock to have on hand.
Steve
Share this post
Link to post
Welded up a quench tank today. I got the mig welder in the shop up and running yesterday and used it today for my first time not stick welding. I think I can run a better bead with the mig than a stick and I've been able to stick weld for almost 10 years (well enough to call it a weld at least).
Share this post
Link to post
Does it leak? Bear this one fact of welding life in mind. Mig welders make better LOOKING beads, NOT better welds. Migs are famous for "cold lapping" welds, that means lay a beautiful bead that's only stuck to the surface with virtually no penetration.
Not saying you've laid bad welds, just saying to keep your eye open for the possibility of cold laps under beautiful bead till you get used to GMAW. They are NOT point and weld, you still have to make a puddle and fill it.
Share this post
Link to post
Jenifer and Anvil-  Amen.  But don't forget the flux-burn holes in your t-shirts, hands heal, shirts don't! (grin)
Here's what I did in the shop today.  Mostly texturing, felt like about a thousand pieces but it was only 150.  Plus some forge welding of hinges, fabricating barn door roller hardware, forged a half dozen small pulls.  Cut and chamfered track standoffs.
Share this post
Link to post
Nice work Judson,  also, I can match you, and raise one pants on fire.
For a while I used to buy all black T-shirts so they would stay looking good for more than a week. Problem with black T shirts is then the flesh tones under it shine through.
Frosty a lot of the new Pipe welding rigs are MIG. Miller sells a pipe welding setup directly aimed at the pipe layers industry.
When I took my course I asked to get instruction on MIG Pipe. Setting up the machine is key. After its setup properly is pretty much like running stick. For guaranteed perfect welds TIG, of course, the champion.
ED5-4.pdf
Share this post
Link to post
Yeah, I was making sure to get decent penetration. I haven't tried filling it yet, gonna do that tomorrow. I also ran a weld on the inside for more stability and did a second weld over the first one on the outside.
Share this post
Link to post
Test it with water. Yes? It's a LOT easier to clean up if there's a leak and won't cause porosity when you try patching it. If you fill it with oil and it leaks we ARE GOING TO LAUGH AT YOU! :lol:
That many beads is just beginner overkill, no sweat. ;)
A quench tank or similar weld isn't structural so you don't need or actually want to make that many passes. For now you'll learn a LOT faster making single beads and finding out what's not right about them. Make sense? Lighter stock is better to learn on, you can see what's happening from the far side.
Once you start getting proficient, practice on 1/4" stock coupons and test the welds. Say cut a bunch of 1/4" x 2" strap stock in 2" lengths and butt weld pairs. Put it in a vise about 1/2" below the bead and bend it over with a hammer.
Share this post
Link to post
Finished a light (~2lb-ish) cross peen I’d been working on. Sweet little thing; I’m looking forward to trying it out.
(This was from a piece of shafting from the industrial surplus warehouse. Sparks like 4140, as best I can tell.)
Share this post
Link to post
Nice work John.
It was my daughters 1st birthday today, but my little shop time is in getting ready for a fair this weekend. Pretty much everything is packed up so other than a little morning shop time I'm probably done for the weekend. I offered to pass on this show since we were going to have a party on this weekend for my daughters 1st. It's been a great fair for me so my better half insisted I do it and we'll have the party next weekend.
Pr3ssure, if you want help with wire feed welding, I'm not too far away.
Share this post
Link to post
Happy Birthday, Ayana!
Share this post
Link to post
Thanks das, I just watched some videos yesterday and luckily the wire in the welder was flux core. I didn't even know you used gas with mig until last night. It's just a little Miller running on a 120 v plug. But it seems to do alright for smaller stuff. The plate I used for the quench tank was like 3.something mm, I think that's 1/8th inch. The cylinder was half inch though so I'm glad it worked. My last few welding rods are all broken up.
Im definitely down to plan something out though this summer. Would also love to get someone to help me make a hammer. I've also gotta keep myself occupied in a productive way for 2 years due to some, well err, legal reasons. So I'm gonna be doing a lot this summer.
Also, I have yet to fill it with water.  Will do that tomorrow.
Share this post
Link to post
Getting into hammer making is definitely a good way to keep yourself occupied!
Share this post
Link to post
Thanks John. She had a fun and full day. We took her offroading a bit in the jeep in the afternoon. The only unfortunate part was the weather being cool and rainy. Still a great time.
Pr3ssure, I'm fine with helping some time this summer. I've only helped with hammer making but what the hay, We can make the tools to make the tools. I'm pretty sure I got the steps down. Plan for a long day, and Maybe we can get something done. :)
Share this post
Link to post
Awesome, sounds good to me. I'm hoping to go to the steel supplier in a week or two to see what all they have. I gotta stock up on known steel for tool making.
Share this post
Link to post
Happy birthday Ayana! :D
Flux core is harder than GMAW but a decent welder with practice. If you can get some time with someone with experience you'll get better fast. Take Das up on it it'll be like going to college. Oh sure a weird, spider, roboctopus, etc. critter filled college but advanced learning for sure.
Share this post
Link to post
JHCC Love the hammer.  Looks like it will be a metal mover for sure.
Das. yes happy Birthday for sure.  Funny and not to rush things along as now is the best time of all,  it will go by in a blink.
Share this post
Link to post
A happy birthday to Ayana!  Looking forward to a birthday party photo, Das!
Share this post
Link to post
Not so much for new scars but I did have eight inches trimmed off of my beard. The forge wasn't a big deal but way too close at the anvil or vise.
Share this post
Link to post
