littleblacksmith
I don't have the propane going through the acetylene regulator, just through the hose. The hose seems to be made of a similar material to the propane hose, but I don't know for sure.
I disconnect the hose when not in use so I'm not real worried about it blowing the house up. I also shut off all gas valves before leaving the shop.
Thanks for the warning though, you can't be too careful.
Share this post
Link to post
Ted, look up oxy fuel hose ratings.  There are types that are for acetylene only,  and others that are for both acetylene and propane.  Propane in the acetylene-only lines will degrade the hose- leading to leaks or ruptures.  I figured replacing my hoses was cheap insurance against catastrophe.
Share this post
Link to post
Ted: If the hose isn't marked for propane it's NOT safe to use with propane. You need to discard the hose you used as propane is very chemically aggressive and does B-A-D things to rubber not rated. Just stopping doesn't stop the badness from progressing. I have no idea what the threshold is but welding trade schools were pretty adamant about one use for any length of time is 86 it time.
Share this post
Link to post
Thanks Frosty, I didn't realize that. Apparently there are 2 different ratings of hose: type R and type T. Type R  is the older stuff you mentioned, but type T is tolerant of a wider variety of gases, including propane. The rating isn't listed on my hose, so I'll assume it's the R type. I'll pick up some new hose.
Share this post
Link to post
For one thing if the inside of the hose starts to degrade you can start getting "chunks of stuff" that will block up tips and hand pieces.
Share this post
Link to post
Yeah, I read up on it and ordered some new hose today. For just heating steel, propane works really well with oxygen. Acetylene is almost too hot as I found out the hard way. Started melting things...
Share this post
Link to post
Oxy-propane is great for cutting and using a rosebud for heating---MUCH cheaper than using acetylene!  Doesn't work for welding though.
Share this post
Link to post
Ted, I believe he shows it in the sculpture threads... 'Roses 101' I think it was titled.  Looked like small bits welded to the stem, then ground/filed smooth.
Share this post
Link to post
Correct HojPoj.  I take leftover cutoffs from the leaves and weld them on then grind them.
I'm sure a better blacksmith could chisel them out of the parent stock. ;)
Share this post
Link to post
Getting set up to fill/tig weld 3200 1/4" holes  in 400 aluminum panels that are 64" long and.050 thick for a Frank Lloyd Wright building I am working on. First I have to pop out and sand dents, machine plugs to fill holes, tig weld, sand welded areas and send off to anodizing. This project will take 10 months to complete.
Share this post
Link to post
Yes income is income. When I get finished I will post an update sharing everything that went into this project, from cost to profit.
Share this post
Link to post
Couldn't forge today due to rain, but this beautiful thing came today. Unpacking was better than Christmas.
This is what I call proper packaging
Share this post
Link to post
Today I tried to move a 18" diameter log that was frozen upright to the ground. I was not successful, despite much effort.
I first "undermined" the log about 1" all the way around its perimeter, in hopes of reducing its contact area with the ground. I then had a 5' digging bar under it with a fulcrum about 3" out from the point of contact, and I was putting all my weight on the other end of the bar. The log remained stuck. Log - 1, me - 0.
Is there some technique for this sort of thing that might help? Or do I just have to wait until the ground thaws in the spring?
Thanks!
Share this post
Link to post
Try fire. Build a fire and then shovel the coals around the log to thaw the ground around it.
Share this post
Link to post
Pnut, that idea did cross my mind, but I'd rather avoid charring the log if possible. I may try it if no other method is successful.
JHCC, This IS the stump I use to mount my anvil on. I need to move it to a inside a barn.
Share this post
Link to post
